Very measured as expected Alex, the oldest 19yo I have ever "almost" met!
Whenever I consider buying a different type of car I always ask the question "what will it cost if the most expensive part needs replacing?" The motor usually... Being the son of a mechanic and seeing it happen often, I always take this into consideration. In saying that I have never had to replace one in any of my cars (touch wood) maybe that's luck, maybe it's smart buying? I don't know.
Looking very much forward to seeing and hearing about your mission.
Cheers
Luke
I have own both an RS4 and a 260. The 260 is obviously a better car for som many reasons.
I got 250awkw from the 260 with the following:
PFC - $950
Greddy profec: $450
Pods and inlet pipes: $250
HKS dumps and Nismo front pipe: $800
5 puk ceramic button clutch: $670
RSR coilovers: $850
Installed and tuned: $2200.00
We had a "reputable tuner" from Melbourne come up to tune a variety of cars. The kill list so far is 1 x rb25 and my rb26. Pretty shocking really.
I am on the rebuild road now, this is what is going in:
Group A N1 turbos
Tuneagent exhaust manifolds
CP forged pistons
REV I beam forged rods
Tomei 260 drop ins
OS Giken gears
Clear timing cover (bling - couldnt help myself)
Block has had the acid treatment
Head is getting some minor porting
Sard 720cc injectors
Greddy rail
Bosch 044 pump
Z32 afms
Custom inlet piping (had to do this again due to z32 afms)
Sump baffle kit
Trust PE2 exhaust
Catch can
Full Tomei engine gasket kit with 1.2mm metal head gasket.
I am hoping for around 330awkw. It will cost a bit over $13k installed, this is over and above the initial mods.
Dont break a GTR motor - they are expensive. This is the first one I have blown, I dont plan on doing it again.
Will keep you posted.
PFC - $950
Greddy profec: $450
RSR coilovers: $850
Group A N1 turbos
CP forged pistons
Tomei 260 drop ins
OS Giken gears
Greddy rail
Bosch 044 pump
Z32 afms
Sump baffle kit
Trust PE2 exhaust
Catch can
hey mate u have sumed it up i reckon. doesnt matter what motor and how tough it is, when shit tuners get hold of it they are time bombs. rb25 or 26 or a damn rb20e they are still gonna blow when leaning em out.
i cant see a rb26 rebuild any different to a rb25 build, except alot of stock gtr stuff can stay for 500hp and not so with a 25 engine.
RBNT (sorry mate i forgot your name) dont forget the few important things with a 26 rebuild. oil restrictor in the head and block off the other oil feed to the head, plus i'd be upgrading the oil pump to a n1 if budget is tight, or a jun/nismo one for extra insurance. plus a baffle kit in the sump is not really going to cut any sort of spirited driving and the chance of oil surge. enlarged and baffled sump is a minimum if any hard driving is going to be considered and u dont want to have to worry about starving the bearings when cornering hard or doin a 8k rpm clutch dump launch :laugh:
those parts are most critical and i wouldnt build an engine without them personally, as the expensive costs of aftermarket pistons/rods and that can turn to a mess without proper oil lubrication.
as said though, if u want good power then you gotta fork out for it.
different horses for different courses :)
Brad, thanks for the avdvice, I have N1 oil and water pumps on the way (forgot to mention). I will have a look into the sump - thanks again.
Alex, you will have a ball with the 260 running 250kw. Watch out for the std suspension though, I found mine to be a bit soft. They are great on oversteer, like a GTR but a bit softer. Remember you injectors will be at the limit and the turbos are on the same path. I highly recommend you buy one though - even after the drama's I had with mine. You will love it.
Cheers,
Ken
Edited by RBNT
Thats why id stop at 250....keep it sane/cost effective.
On another note, chances are I am going to overlap my stagea ownerships and swap over all my suspension into the 260RS (apart from rear shocks which ill need new ones, but i know SK does trade-ins :laugh:)
Going to do the same for the stereo, cat and possibly catback.... so yeah. There wont be a rush to get the 260 on the road then either.
Going to just wait until i get my tax return back this financial year, more credit to my name to let me borrow.
Cheers,
Ken
hey ken, no worries mate checkout the forced induction section for the thread on the oil restrictors for the head as its vital to keep the oil in the sump and not fill the head when thrashing it. big oil pumps can drain the sump quicker than it can drain back out of the head if the restrictors aint installed, from the info i've read from sydneykid etc.
good luck with it also, hope u have better luck than i have been having lately :laugh:
cheers
Brad
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
