Very measured as expected Alex, the oldest 19yo I have ever "almost" met!
Whenever I consider buying a different type of car I always ask the question "what will it cost if the most expensive part needs replacing?" The motor usually... Being the son of a mechanic and seeing it happen often, I always take this into consideration. In saying that I have never had to replace one in any of my cars (touch wood) maybe that's luck, maybe it's smart buying? I don't know.
Looking very much forward to seeing and hearing about your mission.
Cheers
Luke
I have own both an RS4 and a 260. The 260 is obviously a better car for som many reasons.
I got 250awkw from the 260 with the following:
PFC - $950
Greddy profec: $450
Pods and inlet pipes: $250
HKS dumps and Nismo front pipe: $800
5 puk ceramic button clutch: $670
RSR coilovers: $850
Installed and tuned: $2200.00
We had a "reputable tuner" from Melbourne come up to tune a variety of cars. The kill list so far is 1 x rb25 and my rb26. Pretty shocking really.
I am on the rebuild road now, this is what is going in:
Group A N1 turbos
Tuneagent exhaust manifolds
CP forged pistons
REV I beam forged rods
Tomei 260 drop ins
OS Giken gears
Clear timing cover (bling - couldnt help myself)
Block has had the acid treatment
Head is getting some minor porting
Sard 720cc injectors
Greddy rail
Bosch 044 pump
Z32 afms
Custom inlet piping (had to do this again due to z32 afms)
Sump baffle kit
Trust PE2 exhaust
Catch can
Full Tomei engine gasket kit with 1.2mm metal head gasket.
I am hoping for around 330awkw. It will cost a bit over $13k installed, this is over and above the initial mods.
Dont break a GTR motor - they are expensive. This is the first one I have blown, I dont plan on doing it again.
Will keep you posted.
PFC - $950
Greddy profec: $450
RSR coilovers: $850
Group A N1 turbos
CP forged pistons
Tomei 260 drop ins
OS Giken gears
Greddy rail
Bosch 044 pump
Z32 afms
Sump baffle kit
Trust PE2 exhaust
Catch can
hey mate u have sumed it up i reckon. doesnt matter what motor and how tough it is, when shit tuners get hold of it they are time bombs. rb25 or 26 or a damn rb20e they are still gonna blow when leaning em out.
i cant see a rb26 rebuild any different to a rb25 build, except alot of stock gtr stuff can stay for 500hp and not so with a 25 engine.
RBNT (sorry mate i forgot your name) dont forget the few important things with a 26 rebuild. oil restrictor in the head and block off the other oil feed to the head, plus i'd be upgrading the oil pump to a n1 if budget is tight, or a jun/nismo one for extra insurance. plus a baffle kit in the sump is not really going to cut any sort of spirited driving and the chance of oil surge. enlarged and baffled sump is a minimum if any hard driving is going to be considered and u dont want to have to worry about starving the bearings when cornering hard or doin a 8k rpm clutch dump launch :laugh:
those parts are most critical and i wouldnt build an engine without them personally, as the expensive costs of aftermarket pistons/rods and that can turn to a mess without proper oil lubrication.
as said though, if u want good power then you gotta fork out for it.
different horses for different courses :)
Brad, thanks for the avdvice, I have N1 oil and water pumps on the way (forgot to mention). I will have a look into the sump - thanks again.
Alex, you will have a ball with the 260 running 250kw. Watch out for the std suspension though, I found mine to be a bit soft. They are great on oversteer, like a GTR but a bit softer. Remember you injectors will be at the limit and the turbos are on the same path. I highly recommend you buy one though - even after the drama's I had with mine. You will love it.
Cheers,
Ken
Edited by RBNT
Thats why id stop at 250....keep it sane/cost effective.
On another note, chances are I am going to overlap my stagea ownerships and swap over all my suspension into the 260RS (apart from rear shocks which ill need new ones, but i know SK does trade-ins :laugh:)
Going to do the same for the stereo, cat and possibly catback.... so yeah. There wont be a rush to get the 260 on the road then either.
Going to just wait until i get my tax return back this financial year, more credit to my name to let me borrow.
Cheers,
Ken
hey ken, no worries mate checkout the forced induction section for the thread on the oil restrictors for the head as its vital to keep the oil in the sump and not fill the head when thrashing it. big oil pumps can drain the sump quicker than it can drain back out of the head if the restrictors aint installed, from the info i've read from sydneykid etc.
good luck with it also, hope u have better luck than i have been having lately :laugh:
cheers
Brad
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
