GK Technologies is now a distributor for Whiteline performance gear.
We can provide their full range at below retail prices.
For their full catalogue please go here: https://www.whiteline.com.au/store/
Once you know the part number please PM me, or email us at [email protected] and we will reply with the price.
BEST PRICES - GUARANTEED
cheers,
Greg Kruse - GK Technologies
www.gktech.com.au
Prices are EXCLUDING freight!!
S13/180sx:
--- Swaybars
BNF20: CA - Front - $202
BNF20Z: CA - Front - $228
BNR20: CA - Rear - $202
BNR20X: - CA - Rear - $202
BNR20Z: CA - Rear - $228
BNF21: SR - Front - $202
BNF21Z: SR - Front - $228
BNR20: SR - Rear - $202
BNR20X: SR - Rear - $202
BNR20Z: SR - Rear - $228
--- Strut braces
KSB572: CA - Front - $161
KSB594: SR - Front - $182
S14/S15 200sx:
--- Swaybars
BNF19: Front - $202
BNF19Z: Front - $228
BNR11: Rear - $202
BNR11X: Rear - $202
BNR11Z: Rear - $228
BNR11XZ: Rear - $228
--- Strut braces
KSB572: Front - $161
R32 GTS/GTS-T:
--- Swaybars
BNF28: Front - $202
BNF28Z: Front - $228
BNR26: Rear - $202
BNR26Z: Rear - $228
--- Strut braces
KSB505: Front - $169
R33 GTS/GTS-T:
--- Swaybars
BNF24: Front - $202
BNF24X: Front - $202
BNF24Z: Front - $228
BNR11: Rear - $202
BNR11X: Rear - $202
BNR11Z: Rear - $228
--- Strut braces
KSB555 - Front - $190
R34 GT/GTT:
--- Swaybars
BNF24: Front - $202
BNR11: Rear - $202
BNR11X: Rear - $202
BNR11Z: Rear - $228
For all other price requests either PM me or email us!!
can you get 33 front/rear camber and pinapples for a good price?
cheers
I can get all the whiteline gear at good prices but we need model numbers.
Please reply back with the model numbers and we'll go from there (this is done to avoid confusion and so we don't order the wrong parts for you)
cheers,
Greg
part numbers for 33 are
KCA347-REAR CAMBER KIT
KCA348-FRONT CAMBER KIT
KCA349-SUBFRAME KIT(PINEAPPLES)
cheers
PM's replied..
Keep the orders coming :D
Listing the prices for those above things would be good...
For all quotes please send me a PM or email us so we can work out the best deal possible.
cheers,
Greg
hi greg,
im looking for lowered springs (not coilover) for r33 gts-t, can you help me?
cheers
Sure can.
The whiteline springs are $147 a pair for almost all cars (including the R33 GTS-T)
cheers,
Greg
how much are the whiteline coilovers for R33?
I couldnt find a price on their site...
The price is approximately $3250 for the front and rear.
cheers,
Greg
is that including postage?
The price isn't including postage but once a deposit is received we can order and you can pickup from us in Werribee.
cheers,
Greg
Prices as per my pm to you on the 6th? :dry:
Sorry mate, for some reason the SAU email notifications have been going into the junk folder.
I'll reply to your PM now.
Greg
What is the ride height for the lowered springs??
Possibly height from centre of rim to wheel arch please..
thanks..
The springs lower the car 25-40mm.
cheers,
Greg
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
