redgtst and me went for a run last night through balhannah, hahndorf greenhill rd and gorge rd.. LOVELY
nice and cold lots of g forces and no piggies.now i need new tyres..... doh s03's bridgestone 18/265/35 $549 each ouch.......
https://www.sau.com.au/forums/topic/121675-went-for-a-run-last-nite/
nice.
have you tried the Hankook Ventus K104 's before? they are pretty grippy, and not $550 each!!
nice.
ALL other brands apart from bridgestone and yokohama are SHITE pirelli sux,michelin sux, hankook sux,toyo sux, khumo sux
you only get what you pay for.
when you have 300rwkw RUBBER AINT RUBBER
yeah man, I know - I now see you look at your car like I do at my bike
totally understand and good on ya!
enjoy :P
Well thats a bit shallow other companies do make good tyres. As i beleieve michelin make pretty good f1 tyres. And i'm a huge fan of there motorbike tyres. I like the feel of them and there roll.
Where as my dad likes bridgestone alot.
may i introduce u "R" compound tyre?
s-03<RE-01<RE55s
Those really are the shizzle! We have had a few of our customers change from Michelin Pilot Sport Cups to RE55S's. Cheaper, longer lasting, and better grip on the track :mad:
This one customer bought 12 sets of Michelin's. He paid up front, was pissed because he got charged delivery, fitted a trial set of RE's to see how they compared with the Michelin's, and then had the dilemma of trying to get rid of the Michelin's because he loved the RE's so much! :P
How do the Nitto's hold up?
I believe Whatsisname is still running a set, I remember 555 something on the sidewall.
Last I saw that was able to get a lot of first gear down, what looked like all of second and making close to 300rwkw.
I had brigdestone potenza's on my gtr which has just shy of 300 rwk's and got less than 5,000km out of them. Now at $350 a trye, I thought they were s__t. :D
Now a mate at Affordable Wheels and Tyres told me to try the Hankook K102 tyres . They stick better in all weather and last 3 to 4 times longer. Now at $145 a tyre you tell me Price matters
By the way my tyre size is 225 50R16 92V
Thats my thought's anyway :ermm:
Edited by savage GTR
I have another on the cards..
A set of Federal SS595, apparently one of the better ones.
I believe Sky30 has tried a whole range of tyres on his rb30det 300rwkw rwd thing. These apparently came out on top for grip and were suprisingly cheap.
As cubes said, i have tried a few brands of tyres with my 300rwkw rb30det including Hankook, Toyo, perelli, and found the Federals to definately give the best grip, and last just as long as the others.
You only have to look at Theo Woollett's GTR that runs
9 second 1/4 miles on a set of Federals.
(And they are cheap at $160 for 225/45/17")
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
