For Sale One set of HKS GT2540's Ball baring , oil cooled.
suit RB26.
Turbos are in excellent condition and with low klms still in the car at the moment
$3500
One set of HKS CAMS suit RB26
264 Degrees 10 ml lift
In excellent condition
$1000
$800 change over for standard Cams
Located in Melbourne
https://www.sau.com.au/forums/topic/12183-hks-gt2540s/
  • 4 weeks later...
I may be interested in the second turbo. How does $1500 sound. I live in Melbourne and can inspect, pick-up and pay cash.
Can you please supply all specs related to these turbos, via PM or e-mail: [email protected]
-Does it bolt straight on to a RB25DET ex. manifold and plumbing mods are required?
-How old is it (km and months)?
-why are you selling it?
-What are the specs?
-Is it high or low mounted?
Thanks for your time and help. Hope to hear from you soon.
ALAN C.
https://www.sau.com.au/forums/topic/12183-hks-gt2540s/#findComment-274692
PM'd you the info
Here are some specs for anyone else interested
HKS GT2540 - 350 PS Output
COMPRESSOR:
-Wheel- 46 Trim - 51.7 Inducer / 76.2 Major
-Housing- 60 Inlet / 50 Outlet - 0.60 A/R
TURBINE:
-Wheel- 76 Trim - 53.8 Major / 47.0 Exducer
-Housing- T3 inlet / Internal Skyline Type oulet - 0.64 A/R
https://www.sau.com.au/forums/topic/12183-hks-gt2540s/#findComment-275166
Sir Bean, 250 rwkw is 375 bhp, so the 350 bhp rating looks about right. HKS freely admit that their turbo ratings are about 10% less than what the turbo can actually do in an ideal situation ie; 350 bhp + 10% = 385 bhp.
Plus some dynos read more than others.
Hope that helps.
https://www.sau.com.au/forums/topic/12183-hks-gt2540s/#findComment-277387
  • 2 months later...
  • 2 months later...
  • 7 months later...
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
