Extreme 9 puck cushioned button with antiburst cover. $850 supplied , fitted with machined flywheel and includes new thrust bearing.
Have them in everything from SR's to GTR's and will hold up to 350-400rwhp.
Extra $30 if your gearstick boot seal is leaking which 90% of them do.
Cheers
Ken
https://www.sau.com.au/forums/topic/121880-new-clutch/#findComment-2248158
Cheers
Ken
awsome clutchs :D ken and the boys put one in my r33 over 2years ago.. still going strong with my new power level and the abuse i give it at the drift prastices
https://www.sau.com.au/forums/topic/121880-new-clutch/#findComment-2256719
I've got a brand new genuine Nissan R33 clutch sent over from Japan sitting at home, willing to part with it for the same price I paid for it.
I bought it thinking my extreme clutch one was dodgy but it turned out to be fine just not adjusted properly. Pm me if your interested.
My 33 has got a Extreme ceramic clutch as well, good clutch when adjusted properly, pretty jumpy though.
-michael
https://www.sau.com.au/forums/topic/121880-new-clutch/#findComment-2257216
Cheers
Ken
How are these to drive on every day?
https://www.sau.com.au/forums/topic/121880-new-clutch/#findComment-2275249
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
