Serious Accellaration Problems!!!!.....HELP....
Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
Yes, unfortunately that's the one. Signal was noisy to begin with; after driving once and looking back at the logs I saw pressure constantly swinging between 0-200psi, or staying at 0 randomly for a few seconds. There's a lot of good sensors that share the same look and feel, so don't presume they're all bad. I bought mine for 20$ off Amazon and I should have read the reviews prior, as it's clear they're junk. I purchased a lowdollerr motorsports sensor. -
wedding eh.....I seem to get to more funerals than weddings or christenings these days....
By soviet_merlin · Posted
Yep, cheapest options, neglected and abused. The fastest way to dislike a car is to get assigned that model by a budget rental company -
The noise complaint could be from absolutely anywhere, and anyone. Get it actually noise level tested to find out if you're actually over, or if you're fine. If you're over, quieten it down. If you're under, carry the test results in the car with you.
