Hey ppls.
Some of you probably alreay know about it, but I just found out.
There's a movie sharing site called Vidiac.
Started by the guys who run Streetfire.net.
Allows you to create your own Video Sharing Community on the net.
Might be a good idea to set up our own to host the videos we take from DECA, drags, etc etc.
And it can be almost 100% around Skylines/Stags/Nissans and the stuff we like.
Whatta ya think?
BASS OUT
https://www.sau.com.au/forums/topic/122346-vidiac/
So anyway.
I made out site up.
http://skylinesaustralia.vidiac.com
Start uploading Videos people.
It looks pretty bland right now, but that's cos I've done nothing with it but create the community.
I'll ask somebody to make it look like ours soon.
Anyone wanna volunteer?
Prank, who is good for this sort of stuff?
BASS OUTps. I uploaded one of my favorite drifts!
https://www.sau.com.au/forums/topic/122346-vidiac/#findComment-2259375
Cos you can rate and comment on and stuff like that on Vidiac.
I wasn't aware that you could do anything like that on Google.
Can you?
true.. you'd have to build a website manually, with a backend which people could comment on. Not difficult. Just takes time.
Vidiac has it built in by the looks of things. Just I saw the default one you'd setup and it looked a bit basic. Streetfire.net is more like it. Depends how much work is required to turn the default theme into something like streetfire
The other alternative is you could create a new forum on here.. every body posts the links to their googlevideo hosted videos in there, and can comment on there. Then it's integrated directly into SAU and nobody has to setup anything other than a new forum to link to them :D
Few options.. good idea though.
https://www.sau.com.au/forums/topic/122346-vidiac/#findComment-2260197
I thought about those, but because Vidiac is set up to do it, I figure.... use the right tools for the job.
I also considered the load that 25 people downloading videos all at once would put on our server, and I figured that it's best that load is on somebody elses considering all the content we alreay have.
Do me a favour.
Upload some videos to it.
the interface needs to change obviously, but I need to see how it goes with a few videos there. It's having some maintence done at the moment which is why I havent been able to get in there and make it look all purdy.
https://www.sau.com.au/forums/topic/122346-vidiac/#findComment-2260216
I don't have videos.. other than porn. lol.
How do you customise it? Is it a template based system, or do you go in via an admin interface and can customise only certain things?
well I was thinking more with the sau/googlevideo hybrid, you upload and serve the videos through video.google.com... and users post a thread in a dedicated forum on here, say "Skylines Video", with a) link to the video b) description. The thread forms the basis of conversation on that video.
e.g. "my great video" http://video.google.com/videoplay?docid=-7486583767426908809
But ok.. I see how it works now. Either works.
https://www.sau.com.au/forums/topic/122346-vidiac/#findComment-2260218
Hey ppls.
Okay, I've now got admin access that was playing up yesterday.
http://skylinesaustralia.vidiac.com/default.aspx
Start uploading videos!
If there is somebody who wants to help out by making it look a lot better than it does now, and give it some SAU flavour, let me know.
Cos I'm shit at that sort of stuff!
https://www.sau.com.au/forums/topic/122346-vidiac/#findComment-2261450
lol. I might muck around and create a look for it over the weekend. Will let you know if I get any progress...
I just remembered I have a couple of SAU drag vids too.. might upload them as well.
https://www.sau.com.au/forums/topic/122346-vidiac/#findComment-2261713
well here is a look...
pretty basic, but I'm stuffed today. Might be enough so that it doesn't look so bland. I was going to do a nicer collage or something across the top, but maybe later.. or maybe somebody else can get creative on the top area a bit more and I can add it in?
https://www.sau.com.au/forums/topic/122346-vidiac/#findComment-2263260
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
    • Yeah, saw the ratios, not impressed. Would like the punch I have in the first gears now. With those ratios it won't be the same.  Also want the h pattern gearing, or at least a quiet gear set that don't need to come apart for service each year. Looks like the only "reasonable" way Is a 8hp70 transmission, but where is the fun in that🤷‍♂️
