Hey guys,
The name is Jared, i'm a newbie to these forums, and i'm having some problems with my R33!
It seems to be coughing and farting on idle sometimes, now all the mods i have done is a boost controller, fuel reg. and exhaust.
the car is due for a tune very soon once i fit my front mount, but even i know it shouldnt be idling like it is even if it is out of tune.
The car will idle fine sometimes, and others it will drop down to like 500rpm and just start idling like a dog!
I know it could be many a thing so i'm just wondering if you guys would be able to help me and maybe tell me some stuff i can look for to help try and cure this problem , till i have to take it to my mechanic!
i have replaced the AFM, tried adjusting the little red idle box thing at the back of the engine, and yeh im stumped lol maybe something to do with spark or fuel perhaps? Anyways any positive input would be great!
Cheers, jared
https://www.sau.com.au/forums/topic/122348-idle-problems/
Do a bit of a search for hunting issues, I guess that will probably cover most of what you need to know, I have been having these issues for ages, every time I changed something it would stop, then be back the next day - Its because the climate control ac is the problem! I would switch it off to test, then flick it on the next day! oh I laughed so hard when I figured that out ;) lesson one, change only one thing at a time...
https://www.sau.com.au/forums/topic/122348-idle-problems/#findComment-2259369
The same thing was happening to my 33 GTS-T...
Was my fuel pump, it was on the outs and had to get it replaced when i got it tuned anyway... but idle was horrific and sumtimes when i had to stop suddenly the car would fall to 200 or otherwise stall....
Hope this helps....
https://www.sau.com.au/forums/topic/122348-idle-problems/#findComment-2260840
    • Lol a few are like that with no intention of being reborn unfortunately.
    • Done, I'll do mine soon too - whenver I take out the car next. I can cheat and make it quieter by turning off VCT at idle too - but I lose the braps
    • All trim back in wired running driving. Few things to follow up on but not far off the return to the road. att.6HN4wP38LTIOISkhA8eACoBFqzfgQMahZPLA8ut0pqE.mp4 att.w2q0ux2PGuqgQTj2Os13cNHQtqcSEcCAhD_CAXy_IQM.mp4
    • The trouble with phone apps is that they really do not know the sensitivity of the mic on each specific phone, whether there is some sort of cover or skin that can change that, etc etc. So the readings off them are not calibrated. You certainly couldn't be sure that you were even within 3 dB. I have the same app on two (actually more than that) different phones/tablets and the readings in the same room at the same time are never the same. I don't mind the apps - they are as useful as a dyno - if you're testing for delta from thing1 to thing2. But not to try to generate some sort of absolute value.
    • I'm gonna use the "Sound Meter" app from the Google Play Store and as close as I can bother to these procedures: 4. TEST METHOD FOR ALL VEHICLES EXCEPT PRE ADR83 IN-SERVICE GOODS VEHICLES AND OMNIBUSES 4.1 Microphone position 4.1.1 The microphone shall be directed towards the orifice of the exhaust outlet and shall be supported by a tripod or similar device not providing excessive acoustic reflection. The general requirements for positioning microphones are shown in the Appendix. 4.1.2 The nominal axis of maximum sensitivity of the microphone shall be substantially parallel to the test site surface and shall make an angle of 45 degrees ±10 degrees with the principal direction of gas flow from the exhaust. 4.1.3 In selecting the 45 degree alignment from the outlet of a motor vehicle fitted with two or more outlets, only the angle resulting in the microphone being farthest from any other outlet must be used. National Stationary Exhaust Noise Test Procedures for In-Service Motor Vehicles Page 3 4.1.4 The height of the microphone above the test site surface shall be equal to that of the orifice of the exhaust outlet ±25mm but shall not be less than 200mm above the test site surface. 4.1.5 The distance of the microphone from the exhaust outlet orifice shall be 500mm±25mm. 4.1.6 [Relates to vertical exhaust outlets] 4.1.7 For vehicles fitted with one exhaust outlet the microphone shall be placed so that the greatest possible distance is achieved between it and the vehicle. 4.1.8 [Relates to multi exhaust outlets] 4.1.9 [Relates to multi exhaust outlets] TLDR: 200mm off ground 45 degree angle relative to exhaust flow 500mm from tailpipe exit. (I probably won't use a tripod) Here's a photo, cause I read the instructions wrong myself.
