Hi all. Just want to get some help from you guys. Thinking of selling my R33 gts-t and getting a Stagea.I am getting different answers about the 260RS and the AUTECH. Are they the same or not. I rang Shannons and got two different quotes for them . The Autech was about $300.00 dearer.
I then spoke to a guy who is selling one and he said they were the same. Could anybody give me the proper answer please.
https://www.sau.com.au/forums/topic/122460-which-one/
there are 2 different types from what i can find
Nismo 260RS http://www.fantasycars.com/sedans/html/stageanis.html
Autech 260RS http://www.fantasycars.com/sedans/html/stagea.html
i have no idea if there is a "standard" 260rs
edit: yeah darrin is right! the nismo version is just a modified autech
Edited by timmmay
https://www.sau.com.au/forums/topic/122460-which-one/#findComment-2261876
Now this is starting to get confusing. Thanks for the help guys.
Edited by kimbod
https://www.sau.com.au/forums/topic/122460-which-one/#findComment-2261882
I am yet to see a Nismo version
Yes Autech put all the good running gear in, so it is the same as a R33 GTR
Brembo brakes, upgraded interior, their own body kit, shocks and springs, drive shafts LSD etc
Thanks Darrin. There is an Autech up there in Q'land I may have to come up and have a look at.
Yeah I don't think we will see any Nismo ones here yet or ever
https://www.sau.com.au/forums/topic/122460-which-one/#findComment-2261899
If it is a black one?
PM me who is selling it
There is or will be a doddy guy selling one up here that I know off, you want to be aware off
https://www.sau.com.au/forums/topic/122460-which-one/#findComment-2261907
The Nismo model is a seriously limited edition RS 260 autech with a heavily tuned engine and further uprated brakes and suspension 0-60 mph in a claimed 5.1 seconds. The engine is similar to the z tune skyline
It is so rare that the phrase should be rarer than a nismo stagea (instead of rocking horse s**t)
And yes as previously stated an rs 260 is an Autech or the other way round
https://www.sau.com.au/forums/topic/122460-which-one/#findComment-2262893
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
