  • Replies 53
Posted Images
Nice! I fixed my PFC issue too :( Was a blown fuse. Cant wait to get mine tuned at hittman and see what I get :)
Can I ask what mods you currently have to get what you got? PM me if you dont want to say publicly and Was it a power tune or a complete?
No worries mate my mods are:
1995 RB25DET
Standard Turbo
R34 GTT Intercooler
Adj Exhaust Cam gear (set at 3 1/2 deg ret)
CES 3" split dump pipe
Magic cat
Custom 3" into 2 x 2 1/2" exhaust (very similar to Apexi N1 Dual muffler)
GTR Fuel pump
Apexi Power Intake Pod filter (with custom cold air partition)
NGK Iridium spark plugs
hi ryno
i would be interested in talking more about your tune. max power is only one aspect of an ecu tune. theres lots more to be gained in the midrange and the important parts of a tune
Hey Paul,
I am rather fussy with my car, so I researched tuners for a while before I decided to go to Hitman, and I must say he didn't disappoint.
He spent about the same time tuning the cars economy, as he did max power. In fact the max power was never much of a drama, as the first run (with the standard Power FC maps) made 183 kw. I'm very happy with the tune, the car is now smoother than it has ever been, has more power, and uses less fuel. Perfect!
Ryno
holly s##t my car is doing the exact same thing so you say it was a earth will it be the sams if i run all new earths. sorry to hijack your topic.
Hey mate,
It sounds like a few people have been having this problem - here are the places to start looking:
1. Check all fuses - twice!
2. Wire in a direct 12v from the battery to the battery input on the ECU (pin 58)
3. Check earth wires (pins 60 and 50)
4. If it's still not working start checking all the other wires, for a break or something connected where it shouldn't be.
Hope that helps
Edited by Ryno
Hey mate,
Hope that helps
i found the problem it was one of the relays that is up by the computer plug was missing. thats strange that it would run on the std comp but not the power fc. its running beta than ever even with std tune.
That's good to hear mate,
It's amazing how tolerant the standard computer is to blown fuses, broken wires and missing relays! But it can make plugging in the Power FC a nightmare. I'm just glad it's all up and running now, if I never have to solder a wire in my car again, I'll be a happy man.
Good to here I have a r32 with a rb25 in it as well but with the stock comp in it still, fingers crossed I hope the power fc works in it.
buy the way where is (Hitman) located also that power in a r32 should just do a 12 sec ET.
Edited by RB SANDY
Hitman is located in Penrith, he has a web site (www.hitman.hm) though it appears to be down at the moment. His contact number is: 0417259391
I have done a rb25 swap the Hicas needs a speed signal. my car does not have the speed limiter it's bean tested a few times LOL and my Hicas light turns on and off when it fells like will the Hicas still work or should I put a lock bar on it I don’t want the speed limiter.
I had the same trouble with my car... I decided to remove the HICAS and install a lock bar. By doing so you pull about 20 kg of weight off the car, and then I fitted a R33 power steering pump.
You can disable the HICAS (so you don't get that light coming on) by disconnecting the smaller of the two plugs that go into the HICAS control unit - which is in the boot, beside the rear speaker amplifier.
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
