To put it briefly, a few wires running from the siren to the main unit was damaged and then the siren went off. So I turned off the siren with the key and resoldered all the wiring. However when I turn the siren back on, it keeps goin off. I can't seem to do anything about it. What should i do? Is there a way to reset the alarm?
On a side note, the alarm is fully functional apart from the siren issue and the alarm is a Mongoose M80
https://www.sau.com.au/forums/topic/122528-alarm-issue/
I had a similar issue the other day with my car alarm. My siren stopped working, regardless of where the key in the back was turned. So i bought a new Black Widow battery back up siren. Installed it and wired it up, turned the key in the back and it just went off constantley. I spent several hours and almost lost my hearing trying to figure out what i did wrong, before giving up. An alarm guy came and fixed it for me, apparently the siren had shorted out, and was now faulty. i:e even when fed 12volts it would still go off. So he had to install another new siren.
Cheers :yes:
https://www.sau.com.au/forums/topic/122528-alarm-issue/#findComment-2263576
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
