  • Replies 67
Posted Images
i also just noticed that you said its a rb30et bottom end, if thats true then having a turbo bottom end with that head i possibly think could be worse than a bog stock rb20, i know its a big call but i think you could've wasted the little money you spent!
They have different compression pistons.
cheers, andrew!
Rb30et is 7:8:1 and rb30e is 9:0:1, he said he didn't touch the bottom end so that leads me to believe he is going to be a tad dissappointed with what he has!
the rb30 et block has oil squirters to cool the pistons.. the rb30 e does not.
Where did you hear this culater?
I've seen both a turbo and n/a block and they were identical apart from the pistons.
I bought the n/a one sitting next to it for $150.
I remember it was mentioned some time ago by some one who confused the bore/rod squirters or what ever they are called with the piston crown oil squirters.
The bore/rod squirters squirt oil on to the load side of the bore.
Not sure of the exact terminology.
the rb20 head has a smaller chamber but has been cc d it also has the turbo et bottem end so it should not be 7.8.1 it should work out around the 8.5 -9.0.1 witch should be great just gotta finish painting my bay then motor goes in and car goes down to boostworks
: >_< I'm afraid you've got it round the wrong way buddy, having the turbo bottom end with the turbo pistons will lower your compression, not raise it. I'd be guessing somewhere round the 7:1 mark which should be interesting to say the least!
