wow thanks frinik - its on youtube hehe! should get a few more viewers now :wave:
I did a basic storyboard showing the keyshots I wanted in the animation (engine shot and brake disc shot for example) but I made a more involved animatic for the sequence and then built it up from there. after that it was just a case of adding layers of detail :(
