s1 standard white bar exelent condition
2 x crank angle sensor
2 x glove box
2 x lh side a pillar trim
full set of door rubbers
2 x hicas
1 x rear window glass
1 x rear bar reo
1 x set s2 door trims imaculate
1 x set s1 door trims
1 x set rear view mirrors
2 x set kick panels
2 x brake boosters
1 x full manual pedal set
power steering canister
passenger side window motor and rail
drivers side window glass
1 x rear seat
rear quarter trims x 4
2 x s2 boot locks
boot trim
turbo manifold
as these parts are cheap iyou will be dealing with my girlfriend as i will be over seas she wont be able to send pics so look in my posts in campbell if you want to see pics also dont enquire unless u are serious i am sick of people enquiring then saying they dont want the parts thie cheap so if you want a bargain call
mobile 0401280400
all parts are $30 each dosnt include shipping.
thanks
  • 3 weeks later...
Do U have the heater matrix (the small radiator that exchanges air for the heater) just the bit that bolts behind the center console?
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
