hi guys, i'm building up my rb 25det with gtr rods and arias pistons.
I have ben checking out acl for main and big end bearings.
They have two types of each duraglide, and race series.
I plan on using a gt 3037 and using the car for track and road use.
Are duraglide good enough for my level?
Also are new guides and a strong bolt set essental?
If so where do you recomend getting them from
thanks simon.
https://www.sau.com.au/forums/topic/123297-rebuilding-rb-25det/
thanks simon.
What gt3037 are you going with ? The .63 or .82 exhaust flange? Internal or external gate? :)
Edited by 217/r33
nis-i'm going to get the block and head machined and built by nigel at raceline with standard crank rb26 rods arias pistons. Keep the head the same and change cr to 8.5 using hks or similar head gasket.
Assembling the rest myself with a mechanic mate.
217/r33-ive been told that the .63 int gated turbo will suit my needs. Thats with some cams thrown in.
Any help is appreciated, simon
The larger rear housing is only going to affect spool by around 400-500rpm.
eg. .63 comes on around 3600 and really quick delivery
.82 comes on around 4000 a more smoother delivery than the .63 and have a greatwer top end.
The 3037 isnt a large turbo really, it will go very nicely on an RB25 with the .82... or .83 or whatever it is that it comes with
Usual injectors/ECU/clutch/fuel pump etc etc.
Im sure Nige & Karl will sort you out mate. They are definately on the ball.
EDIT: If Nige is doing the bottom end, he will know what bearings to use etc.
N1 oil pump and a collar to suit on the RB25 crank aswell
abo- what are these squish zones you talk about? what sort of head work? port? polish?
i was told head work was not needed for what i was after. Are there problems with using a thick head gasket to achieve 8.5 cr?
Ihave also been told that o-ringing the head and or block is noot needed for my power levels.
can someeone explain this also?
thanks simon
Edited by handyandy
If it was my choice - i'd leave the head alone aswell.
For your power goal... unless you have money to burn, then not really worthwhile.
I ran over 300rwkw with the stock RB25 head :rofl:
...but whats the price of Jap head gaskets that lower the compression to around 8.5:1? Not all headwork is expensive, i suppose it depends if its the ports or chamber you tweak...so food for thought
The Tomei gasket that was used would hardly break the budget... and i would be confident its cheaper than a port/polish etc.
If i remember ill find out how thick it was...
I wouldnt say a lot to be honest. The car was more zippy off boost before the gasket. Although im sure tuning has a fair part there.
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
    • Yeah Jap import. Fairlady Z then! I'm a bit the same.  They've been on my radar for a fair while but then just impulsively decided to buy one!  Was going to just buy an NA and add turbos to it later but decided to save the f'ing around and just buy the turbo version.
