Hi guys im interested in buying a 97 stagea but i havent actually seen a manual one there all auto's so i wondering if anyone knows if they actually came out of the factory as a manual aswell? If not has anyone does a conversion to a manual for these cars and was it hard to do or not worth doing?
Any infromation given will be helpful
Thanks
https://www.sau.com.au/forums/topic/123329-stagea-question/
You should go to the stagea discussion section, lots of information in there...as far as im aware stageas 96/97 were only made in auto.... series 2 came in manual...some ppl have done a manual conversion to their 97 stag's but you can check that out in that section...coming across manuals are pretty rare and can be quite expensive....lucky enough to have a series one auto and a series 2 black manual in our driveway :)
https://www.sau.com.au/forums/topic/123329-stagea-question/#findComment-2278157
Thanks
No, the 97 was the series 1, only available in Auto. thre are quite a few of us in the process of doing manual conversion, myself included. they're not too hard, as now we all have the part numbers for what bits you need. if you like manuals then yes it's definately worth doing. try and find a cheaper stock stagea and then convert that, it'll be much more beneficial.
https://www.sau.com.au/forums/topic/123329-stagea-question/#findComment-2278692
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
