hi Lee
Just spoke with the manufacturer and he is finishing off all the pipes for this GB in the next couple of days. They will get sent out by the end of the week, so you should all recieve them mid next week. I will keep you all informed. Thank you for being all so patient!
Jackie,
Until all the pipes are sent out in this GB, the second GB wont start. So its likely that #2 will begin next week.
cheers
  • Replies 108
hi Lee
Jackie,
cheers
Thanks for letting me know.
I would like to please grab one next week in the #2 group buy please, if u havent already noticed :cheers:
hi Lee
Jackie,
cheers
Cheers mate!! :blink:
hi guys,
just an update on the pipes. 3 are being sent tomorrow:
STAGE-A
siddr20
skyline17
Everyone else's pipes are getting sent on Thursday, and that will be all the remaining people in the GB. Again, i apologise for how long its taken to get them sent out!
I have said this before, and I will say it again - fantastic product. Worth getting them, as the car just feels soo much better to drive. More responsive now - im almost tempted to take out my TRUST PE2 catback and seeing how it is with the standard exhaust installed.....
i will start another one on friday. but it will be a limit of people this time, otherwise it takes too long for all to recieve their pipes.
once again
please put me down. im extremely keen to do this. :laugh:
im 1st!!!!
hi guys
All pipes have now been sent out. Some should recieve them tomorrow, and all the rest will recieve them by early to mid next week depending on where you are located. Thank you to all who participated in the GB and for those that are keen on a second one, i will put up a thread today in the GB section. They will start to get made from today, this way most will be ready to send by the time the payment is due.
cheers
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
