Hi I just r32 gtr while I driving sometime hicas light flashing and steering wheel heavy when light flashing look like no power steering.My car has momo steering wheel anything to do with that or something relate to this problem such as wheel aligntment or something else.Please help .thanks a lot
Which boss kit did you use for the Momo wheel? There are two available for R32 - one for early models and one for late models. THe HICAS lugs line up differently and will cause HICAS errors if you use the incorrect boss.
I don't know .The momo come with the car but I wil check that thanks
Bob I'm pretty sure the two kits are p/n ON-110 and ON-115.
The early R32s have HICAS lugs at 2 and 8 o clock, and the late model (series 2 with textured ashtray + surround) have the HICAS lugs at 12 and 6 o clock.
Hope it helps.
Hope it helps.
MY one is 1989 it should be early one and it should be p/n 110 it that right thanks
Hi mate. Yes, it'll be the early one with the lugs at 2/8 (ish). I'm pretty sure it is the ON-110. If you ring Autobarn and ask for a p/n on the Momo boss kit to suit Skyline "with SuperHICAS" (that's what is written on the box and in the lookup book). Whatever p/n they tell you is the one for the LATE MODEL R32.
Please let me know if I can clarify further, it's easier to talk about it over the phone. If you pull the wheel off you should be able to find a p/n somewhere...?
THank mate I will try ring them tomorrow
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
