  • Replies 121
Posted Images
reading this wants me to put a 26 in, just bringing up the old thread. just wondering whats the cost of getting to engine in??
ALOT.
You need to be handy with a Tig welder and air hacksaw as well just to mod the sump. Then youll want to freshen up the motor, need a 25 gearbox, a decent clutch, custom tail shaft, new cooler piping, etc, etc, etc. Also if you cant do it yourself (or have good mates) the labour is going to kill you as well.
Steve
As i have mentioned a few times i have kept the rb20 gearbox and im not having any problems as of yet. You will need a much better clutch though. dunno about the custom tailshaft. i kept my gtst one. What also make sit expensive is you start to think "While im at it" then you start doin computer upgrade etc. etc. I put aside $7000 for the conversion but spent closer to $9000
If i had a re-do i would have used an rb25 and spent the extra cash on a better turbo
I went for a 34 gt-t box and hks twin plate. Being a bigger box the shaft had to be shortened. I also went for a pair of 2530s, and a powerfc, as well as afm upgrades, nismo injectors, etc. Total cost has blown well out now but :domokun:
Im making about 310 rwhp at the moment. stock turbos running 11 pound i think. Its gotta go for another tune yet though hopefully get some more out of it.
masters where you talking 300hp or 300kw?
Awesome. Should be a unique ride. Is it gonna be a sleeper or are you doing it up?
what ecu you gonna run?
It will be set up for track work .. Ordered PFC D jetro
Flash89 you can make a comfortable 300 on the stock GTR turbos. Id recomend you just get a RB25 if your on a budget.
DISTURBD you going big single?
No big single , after doing the Dutton with the 25neo 31 we decided we needed that little bit of xtra grunt so building whole new car for next yr
Dont need to do steering rack, im just fussy.
Dude, there is enuf info in this topic to write an essay on the conversion. Read up, get some serious cash together, and get on it.
If its too much, RB25's are cheap, put one of those in.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
