hi guys ive recently bought a r33 gts t
im new to these cars and the a lsd light comes on sumtimes for no reason as far as i know can any one help me with this is this a common problem and also are there certain hydraulic pumps and computers to check for the lsd or anything like this any info would be great cheers
https://www.sau.com.au/forums/topic/123814-a-lsd/
Yes skylines can have an A-lsd light.
It means you have an active spec LSD version of the skyline.
Run some searches there's a shipload of info on this site about the A-Lsd.
As for it intermitently turning on. Do you have a power-fc? If you do I strongly suggest you look at the signature of a guy on here called PaulR33 as this is a fault that happens with the A-lsd failing and power fc's, but he's got the cure (read: DIY) to fix the problem.
If you don't have an Power FC.
Perhaps a fault with your abs sensors or the computer itself, or the hydralics, or a lack of fluid?
https://www.sau.com.au/forums/topic/123814-a-lsd/#findComment-2286171
Some Gtst's came with the vspec diff you are very lucky as they are a rare option.
The A-LSD light in the tacho it only comes on if there is a problem. The ECU for the ALSD is in the boot. Does it stay on always or just come on now and then?
Chris
https://www.sau.com.au/forums/topic/123814-a-lsd/#findComment-2286173
Nah, Actually, this site is pretty gay regarding a-lsd. I keep asking about certain things about a-lsd.
No one knows what fluid it uses. no one knows how to bleed the system.
No one actually knows how it performs relative to the normal gtr 2way diff.
Searching will get you info about fully sik people talking about fully sik stuff. but nothing actually useful about the a-lsd.
Like there's info about how people have installed fully sik power fcs into their fully sik skylines to make them fully sik and go quicker.
does someone actually know anything useful about the a-lsd? if so, please post.
https://www.sau.com.au/forums/topic/123814-a-lsd/#findComment-2286188
Check fluid in a space in the boot on the right hand side, you'll see a little canister behind a little clipped on segment.
The fluid it takes is power steering fluid.
As for the microtech, this might be causing the problem, from memory the A-Lsd computer requires a signal from the ECU that aftermarket computers generally don't give and have to be modified to suit.
Here I've run the search for you, check this link out:
http://www.skylinesaustralia.com/forums/in...howtopic=107656
Now I realise that you don't have a power Fc, but the premise behind the solution should be the same for the microtech.
https://www.sau.com.au/forums/topic/123814-a-lsd/#findComment-2297867
hmmmm. i love it when people get credit for my work :
putting it simply.. while driving the light will come on when the wheels slip. (lets you know its working)
if not. you need to aply the tps signal to the a-lsd ecu. just check "moonie" 's topic on a-lsd. i fixed it for her at wsid :dry: with a multimetre and some eletrical tape :)
https://www.sau.com.au/forums/topic/123814-a-lsd/#findComment-2300251
if not. you need to aply the tps signal to the a-lsd ecu. just check "moonie" 's topic on a-lsd. i fixed it for her at wsid :) with a multimetre and some eletrical tape :whistling:
Hey man, apologies, credit where credit's due.
I just remembered following the post about the fault with the A-Lsd (As I have one in my car, but my ecu is still standard), and remember Paul copying it to his link on FAQ on A-Lsd's.
https://www.sau.com.au/forums/topic/123814-a-lsd/#findComment-2300910
how about if someone actually says how to blled the syhstem and what fluid it uses?
There is a bleeder nipple on the right hand side under the car runs along the right hand chassis and is roughly above the diff cradle. Make sure the car is running and bleed out the air from there.
It is difinitley power steer fluid. It will also read low when the car is off! So don't over fill it.
https://www.sau.com.au/forums/topic/123814-a-lsd/#findComment-2301216
cheers for all the info guys i mite attempt to bleed it on the week end there is red oil ontop of another coloured oil like some one said on a previous post in my canister so i mite replace it can anyone tell me a specific type of oil to use and a rough price
cheers guys
https://www.sau.com.au/forums/topic/123814-a-lsd/#findComment-2308992
    • Hi from Canada, Both of my calipers are starting to fail. My car is a 2005 M35 Stagea ARX and I can't seem to find any parts or any cross reference caliper that would fit my car. Is there a company or a similar caliper that would fit and I could replace the OEM one. Or if anyone knows where I can find a new OEM. Any help is very appreciated. Let me know!
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day   Highway gets as low as 10l/100km on my end so I'm not as worried about it being a mechanical issue. More likely just the tune on the haltech.
