Hi
Just bought the above & battery is shot (still has battery from Japan) & i need a replacement...
I HAVE DONE A SEARCH but all the posts i found were relating to coupe's with the battery in the boot & mine is in bonnet as its a sedan
What battery should i get that is better than std & will fit in original holder & attach to std terminals but wont cost an arm & a leg
Thanks
There's a group buy on Calcium batteries 550cca sealed items which would fit your R33 alright. you might need new clamps from repco or something though, it's quite a bit beefier but not *too* big.
Other than that, maybe odyssey or red top optimas.. but now u're talking a few hundred dollars.
How many CCA's is Std Battery & is terminal post std or small?
Also what do you guys think of these
http://www.gsyuasabatteries.com.au/asp/ind...ype=40&type=377
http://www.gsyuasabatteries.com.au/asp/ind...ype=40&type=379
Wanted this one but oo big to fit
http://www.gsyuasabatteries.com.au/asp/ind...ype=40&type=365
Thanks
Edited by Noel
The ones you've listed are still lead-acid maintenance batteries. I'd imagine you could go anywhere for that sort of stuff (big w's, repco, supercheap) etc.
I can't really tell you what you need for your setup, but if you're looking at replacing the stock battery then you ought to be looking around the 330cca mark (well that's what was in my stock r34).
My setup is stock std mechanically & im running one amp & a 10" sub of a MP3 HU
imagine you have an alarm also? and you're not going to be running your system at full blast for extended periods of time with the engine switched off?
You'd get away with a 500cca lead type battery ... i had a similar setup in my previous beast (kicker 354xi amp, 12" rockford, stacker/hu, a few electronic gizmos) and i ran a similar battery without ever any startup problems.
The main reasons why you'd want to step up to a gel cell or fully sealed system are:
- often are deep cycle
- don't leak gas
- no maintenence
- can relocate into the boot
- often can be smaller than factory battery (talking only about the optimas and odysseys here)
- greater cranking capacity
downsides are of course ... cost.
Hope this helps you.
edit> in summary... don't be tight.. go the > 500cca lead-acid as bare minimum, go the gel cell if you need that overhead. :D
Edited by Howie
- don't leak gas
- no maintenence
problem is size...the one in there now is only 200mm Long, 130mm Wide & 190mm High with small terminal posts & i cant see anything bigger fitting in there at all & most batteries with a decent cca are at least 172mm wide & 239mm long
I don't know if they're easy to come by or not, but my mate who is an auto sparky put an AC Delco sealed lead-acid in mine - circa 550CCA - runs rings arounf the old 'Exide' that was in there when i bought it. Starts easier, and just plain starts after working on the car with the stereo on :D
Just thought id add my 2c.
NOTE ; It is also a very small battery, similar in dimension to what Noel described, small posts included.
Edited by pstanbis
it isn't essential for a sealed battery if it's up the front. Now that iv'e owned a skyline with a sealed battery, i would never go back thouguh.
no more acid spills, no more acid powder and rust everywhere etc.
You don't need such a massive battery. Before my stock battery died, the stock 330 cca battery worked wonders.
Hi
Thanks
I have a Rocket 452, 550 CCA, L 240mm W 174mm H 212mm. It fits alright. Longer brackets required. A point to note, if you want to change headlight bulbs, do so before you upgrade to a larger size battery :D
    • Yea that's a fair assumption. I'm presuming they call them solid lifters as they have no moving parts like hydro lifters.
    • I believe you're confusing WMI with water injection. Looking at that graph, the 93aki+WMI car is making more power than C16 race gas. Boost juice, which is what I also run, is Snow Performances 50/50 premix.
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
