Hey guys,
Ive got a 1995 r33 GTS-T
Just wondering if anyone has come across a similar broblem as mine....
the car dirves fine for a few minutes, then out of nowhere loses most of its power, the revs drop between 500-1000rpm during idle and it seems like its hunting!
Then 2 minutes later it will be fine again and drive as good as new?!! :cool:
I've been told it could be anything from a faulty injector/fuel pump/spark plug/coil/airflow meter!
I dont want to go changing all these parts as obviously all of them cant be faulty! (i hope)
does anyone have any advice as to what it might most likely be?
https://www.sau.com.au/forums/topic/124015-problems-with-my-r33/
sounds like a vaccum leak , during idle if fluctuates thats normally the cause , check all you cooler piping
also how old are your spark plugs? Have you gapped your spark plugs to 1.1mm or if boosted 0.8mm?
Edited by mr_crust
yep all the piping is secure and its running standard boost (never been boosted)
i've purchased a S2 airflow meter... as ive been told that is the most probable cause!
I will let you know if it fixes the problem.
thanks
    • From my youth: GTi-R clutch change is a massive pain. The gearboxes are fragile? But the car is super cool and I want one 馃槩
    • Remember this is 1988 tech.
    • Driveline vibration is resolved. I ended up loosening all my engine mount and trans mount bolts, giving it a good shake then retightening everything and it's gone... Let's just say I was surprised that fixed it.  I've been happily driving it around again but unfortunately put zero time into my direct port/constant pressure WMI setup. I'm on vacation next week, so I'll try and finalize it then.  On a different note, I spent all week fuel/ignition mapping 2x 216L V16 engines. Turbo's were burning glycol and we swapped them out for larger units. We also had planned emissions testing on site, so I figured I'd be there the same week to use their instrumentation and massage any emissions issues out if needed. This was a first for me. Fuel management is similar in certain ways to automotive (i.e air density as load variable) but very different in others. It's all PLC based and AFR's are controlled by air and not fuel. They use a control valve between the turbo and air manifold to control pressure which in turn controls AFR's. Due to this, target AFR tables supplied by the OEM are in pressures and not mass which really through me off. They use air pressure vs fuel pressure tables. I also relied on an O2 concentration sensor the emissions team had in the exhaust. Ignition timing was also all over the place and we were losing a fair bit of power. They're now happily sitting at 16-40BTDC depending on load. We were making about 1600kw at 900rpm at 90% load. Engines were running a lot smoother as well.
    • heh, aint no R32 ever meeting modern targa cage rules unless the driver is veeeery short OP, good luck with the sale, since its already in the land of freedom I'm sure you will find a good buyer.
    • meh, it was a good video, clear about the issue and how he dealt with it. A bit heavy on the RTV and very brave to put an RB in anything without rebuilding it first, but otherwise I thought it was good Dose, I'm not sure that having the pickup forward is a big issue; yes of course the oil could shift under brakes but the sump should never be empty enough for that to be a problem (unless you also have a higher volume oil pump, and that oil can't return from the head to the sump quickly enough)
