ok, my r33 has an atmo bov on it and ive noticed that it sometimes idle kinda wierd and other symtoms of a non plumback bov. well looking at getting a plum back bov when i get my tax back and i kinda go nfi how to go about the plum back part...
like what size hose etc and where it reconnects before the afm.
ive attached a pic (i work better with pics...) and yes the airfilter is due for a clean i think...
any help will be appreciated :P i think the afm is the thing after the pod right? (my last car was a commodore and less technical :) )
https://www.sau.com.au/forums/topic/124114-going-from-an-atmo-bov-to-plumback/
its all there ready to be clamped on. there should be something blocking off the hose so take it off and attach it to your new bov.
if you've got idling issues i think you should do a search on "AAC Valve" that'll get you started.
If you can mate I recomend going back to the stock BOV, can handle plenty of boost and give you no dramas like the Atmo. It looks like your intake pipe isnt standard though, so u might have some dramas, have you got a photo of where your BOV is mounted?
Cheers
Take a pic of the crossover pipe so I can see if the factory Bov is still on there, mine had a thin plate between the crossover pipe and the Factory BOV that blocked it off and all I had to do was remove that plate and block the atmo hole off .
in that case its just a matter of swapping them over. it consists of 2x12mm bolts holding the BOV in, a vacuum hose and a hose with 2 clamps to fit onto the stocky.
i'll take a pic of it close up for you tomorrow.
yeah the thing with the grey cap. if you open it the little dipstick (about an inch long) will have a line on each side. one has hot, the other cold. this is due to the fact that the fluid expands when hot (or is it cold.... i can't remember). but anyway check it according to whether it is hot or cold on the corresponding marks.
With K&N filters they rely on some dirt to help aid filtering, but without effecting flow levels.
So making it really clean again will mean more particles going into the engine.
I don't know how dirty it is, from those pics, just be-aware that some dirt is required to get them to filter well. (Its all stated on the back of the boxes)
I hate when people do a filter test for filtration levels and they use a brand new filter and and say K&N doesn't filter as well as other filters.
Yet they don't realise or state K&N specify some dirt helps it filter properly, hence not needing to be cleaned for up to 100k km in some cases.
oh, never read that... then again ive never bought a k&n filter... it is pretty dirty tho. im tossing up buying the cleaning kit thingy or even an apexi pod... ill prob go the cheaper option...
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
