Ok here is the story...
I just bought an R33 S2 Sedan. When i went to see & get car inspected it had been sitting a while so needed a jump start but when i picked up car it was fine & started first go everytime all week...On the weekend my cousin installed an alarm & we also put in a HU & Sub & Amp...Anyhow car would not start after install so we figured battery had been drained due to boot/doors open etc whilst installing so we gave it a jump & i drove home no worries...
Next day go to start car & nothing, just click click click...I did a search on here & after reading many threads I took the battery out, gave it an over night charge, got multimeter out & battery read at approx 12.3-12.5v, so I whacked it in the car & started first go, sweet (i thought)...I checked voltage whilst running & it read 14.18 at idle & rose to about 14.26 under loan 2000-3000rpm so to me alternator is was working fine...
Anyhow i drove to the gym, worked out for an hour or so then came out & it started first go but was a bit slow to kick over...Went home ate etc then went to go out about an hour later & click click click it would not turn over? Thinking maybe something was draining battery i checked again & it was still readin 12.3-12.5v?
What the hell is wrong? I figured it cant be the starter motor cause it jumps fine, alternator seems to be working? & battery has charge? I am Stumped
Please help!!!
Thanks
Noel
https://www.sau.com.au/forums/topic/124228-help-car-wont-start/
New battery needed!
Is the battery you have now one of those "pitwork" ones? If so they normally die pretty quickly. I know during the first few weeks of getting my car I had similar problems.
Also another SAU member's GTR left it for a week and it wouldnt started (Also had a pitwork battery - I think they are std. nissan ones from japan), tried jumper leads, pushing it no go. Changed the battery over to a new one and it worked straight off.
There is a group buy on the FS from wrxhoon who has those dry gell type batteries for $150 I think. Check it out.
New battery needed!
Nah its a Bosch with Japanese writing all over it...
What i dont understand is if its the battery that is stuffed why is it reading 12.3-12.5v??...Can a battery still hold correct charge & work all accessories etc but be damaged in some way (maybe cells) for it not to be able to provide enough voltage to starter motor?
Get a new battery.
Just want to be 100% sure it is the battery & not someting else
With a previous car i thought my battery was dead, went out & bought a GSYuasa then 2 days later that was dead & found it all it was was a bad connection with stereo which was draining battery.
& i still am not convinced it is the battery beacuse according to multimeter its not flat???
Is there a date engraved on the battery? That date would be the day it was fitted. Regular batterys only last for 2 or 3 years depending on what you buy. I had a battery die in my old pulsar, it started up all fine and dandy for 2 years, then one morning the car wouldn't start, so i charged it, the next day it was dead again. So i bought a new battery and everything was fine again.
If your battery is old it probably just karked it.
Not enough amps to crank (Lets get crunk tonite. lol sorry), its not always volts that are required to start a car.
Use a AMP Meter, or best yet get a mutimeter and read the amps. Not sure what AMPs are required.
But I reckon too much trouble as..
Im 99% sure that the battery you have is dead.
Its just like any old recharable battery you may have. (Especially SONY camera batteries, worst ones ever). Charge a battery many many cycles and after many many times it will loose its "chargeablity" (if thats the correct term).
Ok picked up a battery yesterday & whacked it in last night & seems to be fine now ;-) (fingers crossed)
I got myself a battery from a wholesaler called Supercharge Batteries http://www.supercharge.com.au/
Battery i got was MF55B24R. Its 450CCA Has 3Yr warranty & is a zero maintenance battery...Has pencil terminals so no mods required & also is the same width as std battery, so all you need to do is take out battery tray, whack in new battery, clamp it down with original brackets & away you go!
*Note this is for Underbonnet only as its not sealed*
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
