well after spending alot of money and time on suspension... taking the car for a drive last night and notice that its just not going the way she should up in the rev range....
Symptoms
not pulling hard in higher revs
backfiring more
lumpy idle/searching for idle sometimes
can hear miss at idle
Now im pretty sure its one of my coil packs... i know i should search but im lazy....
how can i tell which coil pack it is?
will r33 coilpacks fit in?
anyone got any 2nd hand RB20 coilpacks?
Will she die at a random time? eg crossing harbour bridge at peak hour?
Thanks all, just want to get this sorted asap as i love higher revs if you know what i mean....
Ed
https://www.sau.com.au/forums/topic/124285-farken-coil-packs/
Symptoms
backfiring more
Ed
When did you last change the spark plugs?
What plugs are you using?
What gap are they set to?
:D cheers ;)
PS, turbo cars are killer on plugs, it most likely isn't the coils
:D cheers ;)
plugs got done maybe 30,000km ago
they are igk platinum
set to stock gap
should have another 40,000km in them EASY.....
shes always had a slight miss at idle even with older plugs.... so im thinking one of the coils has been on its way out for a long time now...
set to stock gap
Stock plug gap is 1.1 mm which is too large.
Try 0.8 mm for boost up to 1 bar and 0.65 mm for boost over 1 bar
:D cheers ;)
alrighty, where is the best place to get them regapped?
due to wat ive mentioned im really thinking its one of the coil packs....
im only running 11psi but hits 13 on cold nights
1.1 mm (probably 1.2 by now due to wear of the electrodes) is a 38% larger gap than 0.8 mm.
1.1 mm is a good gap for 6 psi, you have almosty doubled that (plus a bit on cold nights).
Check out the DIY section for R&R and gapping spark plugs, it's not that hard.
:D cheers ;)
alrighty ill give it a go over the weekend...
if it is one of my coil packs ive been told that taking out one at a time at idle and if the idle dosent change (keeps misfiring) then thats the faulty one...
should i test that too?
I don't think I've heard an R32 that doesn't have the odd ever so slight pop on idle. I'm not sure you could really call it a miss as a miss is very pronounced.
From what I've been able to fiddle with the only way to completely remove it is to richen up the idle afr to a shade over 14.
I only noticed my occasional pop on idle once I had the exhaust fitted.
Ed,
If it's not happening all the time there's a pretty good chance it's the coil packs. When you get the coils out, have a good look at the clearish plastic window on the side and see if there's any burn marks, bubbles in the plastic, cracks etc, etc. Also, pull the rubber boot off the end and check out the carbon contact ( and spring ) to see if it's shot. The carbon bit contacts the end of the spark plug and can errode over a long period of time.
When I had my HR31, sometimes the car would be OK but when the coils packs got hot, the fault would show up. I replaced my set with a set that were in much better condition and problem solved.
If you do need coil packs, give me a yell. I've got a bunch of really good condition ones.
Otherwise, have a good look at spark plugs, wiring, connection plugs etc for general condition.
Hope that helps you some :dry:
Had a couple of ignitor failures as mentioned earlier, this will give you simptoms you are experiencing, but as SKid said , start with the basics first, keep in mind the components you are talking about are around 16 years old.
Ed,
Hey dude if you figure out the problem make sure you post back here ok. Im running pretty much the same set up and have the same problem. Had my fuel pump replaced and after that it ran alot better but now its gone crap again so i need to start with some other ideas (which unfortunately there are alot of, my mechanic is convinced that my timing belts off by a gear or 2, but im 90% sure hes had to many spanners drop on his head)
Edited by r32 gts-turbo
I had pretty much the same problem in 1 X R32GTST, 2 X R33GTS's, 1 X R34GTT and 1 X Stagea and fitting NGK copper plugs and gapping them as per the above fixed it in ALL of them.
Why look for the complicated answer before trying the simple and cheap ($20) solution first.
:D cheers :P
and while you have the coilpacks out to change the plugs you could tape them up. kill 2 birds with 1 stone.
But then you won't know what the real problem was.
One thing at a time
Leave the plug cover off until you are happy
Then it is simple to check the coil packs if it's not the plugs
:huh: cheers :angry:
Edited by Sydneykid
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
    • So, what else.... Power. I don't know what it is making because I haven't done a post tune dyno run yet; I will when I get a chance. It was 240rwkw dead stock. Conclusion from the day....it does not need a single kw more until I sort some other stuff. It comes on so hard that I could hear the twin N1 turbos on the R32 crying, and I just can't use what it has around a tight track with the current setup. Brakes. They are perfect. Hit them hard all day and they never felt like having an issue; you can see in the video we were making ground on much lighter cars on better tyres under brakes. They are standard (red sport) calipers, standard size discs in DBA5000 2 piece, Winmax pads and Motul RBF600 fluid, all from Matty at Racebrakes Sydney. Keeping in mind the car is more powerful than my R32 and weighs 1680, he clearly knows his shit. Suspension. This is one of the first areas I need to change. It has electronically controlled dampers from factory, but everything is just way too soft for track work even on the hardest setting (it is nice when hustling on country roads though). In particular it rolls into oversteer mid corner and pitches too much under hard braking so it becomes unstable eg in the turn 1 kink I need to brake early, turn through the kink then brake again so I don't pirouette like an AE86. I need to get some decent shocks with matched springs and sway bars ASAP, even if it is just a v1 setup until I work out a proper race/rally setup later. Tyres. I am running Yoko A052 in 235/45/18 all round, because that was what I could get in approximately the right height on wheels I had in the shed (Rays/Nismo 18x8 off the old Leaf actually!). As track tyres they are pretty poor; I note GTSBoy recently posted a porker comparo video including them where they were about the same as AD09.....that is nothing like a top line track tyre. I'll start getting that sorted but realistically I should get proper sized wheels first (likely 9.5 +38 front and 11 +55 at the rear, so a custom order, and I can't rotate them like the R32), then work out what the best tyre option is. BTW on that, Targa Tas had gone to road tyres instead of semi slicks now so that is a whole other world of choices to sort. Diff. This is the other thing that urgently needs to be addressed. It left massive 1s out of the fish hook all day, even when I was trying not too (you can also hear it reving on the video, and see the RPM rising too fast compared to speed in the data). It has an open diff that Infiniti optimistically called a B-LSD for "Brake Limited Slip Diff". It does good straight line standing start 11s but it is woeful on the track. Nismo seem to make a 2 way for it.
    • Also, I logged some data from the ECU for each session (mostly oil pressures and various temps, but also speed, revs etc, can't believe I forgot accelerator position). The Ecutek data loads nicely to datazap, I got good data from sessions 2, 3 and 4: https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-2?log=0&data=7 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-3?log=0&data=6 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-4?log=0&data=6 Each session is cut into 3 files but loaded together, you can change between them in the top left. As the test sessions are mostly about the car, not me, I basically start by checking the oil pressure (good, or at least consistent all day). These have an electrically controlled oil pump which targets 25psi(!) at low load and 50 at high. I'm running a much thicker oil than recommended by nissan (they said 0w20, I'm running 10w40) so its a little higher. The main thing is that it doesn't drop too far, eg in the long left hand fish hook, or under brakes so I know I'm not getting oil surge. Good start. Then Oil and Coolant temp, plus intercooler and intake temps, like this: Keeping in mind ambient was about 5o at session 2, I'd say the oil temp is good. The coolant temp as OK but a big worry for hot days (it was getting to 110 back in Feb when it was 35o) so I need to keep addressing that. The water to air intercooler is working totally backwards where we get 5o air in the intake, squish/warm it in the turbos (unknown temp) then run it through the intercoolers which are say 65o max in this case, then the result is 20o air into the engine......the day was too atypical to draw a conclusion on that I think, in the united states of freedom they do a lot of upsizing the intercooler and heat exchanger cores to get those temps down but they were OK this time. The other interesting (but not concerning) part for me was the turbo speed vs boost graph: I circled an example from the main straight. With the tune boost peaks at around 18psi but it deliberately drops to about 14psi at redline because the turbos are tiny - they choke at high revs and just create more heat than power if you run them hard all the way. But you can also see the turbo speed at the same time; it raises from about 180,000rpm to 210,000rpm which the boost falls....imagine the turbine speed if they held 18psi to redline. The wastegates are electrically controlled so there is a heap of logic about boost target, actual boost, delta etc etc but it all seems to work well
    • hahah when youtube subscribers are faster than my updates here. Yes some vid from the day is up, here:  Note that as with all track day videos it is boring watching after the bloopers at the start.  The off was a genuine surprise to me, I've literally done a thousand laps around the place and I've never had instability there; basically it rolled into oversteer, slipped, gripped and spat me out. On the way off I mowed down one of the instructor's cones and it sat there all day looking at me with accusing cone eyes as I drove past. 1:13:20 was my fastest lap, and it was in the second session, 3rd lap.  It (or me!) got slower throughout the day as it got hotter.
