well after spending alot of money and time on suspension... taking the car for a drive last night and notice that its just not going the way she should up in the rev range....
Symptoms
not pulling hard in higher revs
backfiring more
lumpy idle/searching for idle sometimes
can hear miss at idle
Now im pretty sure its one of my coil packs... i know i should search but im lazy....
how can i tell which coil pack it is?
will r33 coilpacks fit in?
anyone got any 2nd hand RB20 coilpacks?
Will she die at a random time? eg crossing harbour bridge at peak hour?
Thanks all, just want to get this sorted asap as i love higher revs if you know what i mean....
Ed
https://www.sau.com.au/forums/topic/124285-farken-coil-packs/
Symptoms
backfiring more
Ed
When did you last change the spark plugs?
What plugs are you using?
What gap are they set to?
:D cheers ;)
PS, turbo cars are killer on plugs, it most likely isn't the coils
:D cheers ;)
plugs got done maybe 30,000km ago
they are igk platinum
set to stock gap
should have another 40,000km in them EASY.....
shes always had a slight miss at idle even with older plugs.... so im thinking one of the coils has been on its way out for a long time now...
set to stock gap
Stock plug gap is 1.1 mm which is too large.
Try 0.8 mm for boost up to 1 bar and 0.65 mm for boost over 1 bar
:D cheers ;)
alrighty, where is the best place to get them regapped?
due to wat ive mentioned im really thinking its one of the coil packs....
im only running 11psi but hits 13 on cold nights
1.1 mm (probably 1.2 by now due to wear of the electrodes) is a 38% larger gap than 0.8 mm.
1.1 mm is a good gap for 6 psi, you have almosty doubled that (plus a bit on cold nights).
Check out the DIY section for R&R and gapping spark plugs, it's not that hard.
:D cheers ;)
alrighty ill give it a go over the weekend...
if it is one of my coil packs ive been told that taking out one at a time at idle and if the idle dosent change (keeps misfiring) then thats the faulty one...
should i test that too?
I don't think I've heard an R32 that doesn't have the odd ever so slight pop on idle. I'm not sure you could really call it a miss as a miss is very pronounced.
From what I've been able to fiddle with the only way to completely remove it is to richen up the idle afr to a shade over 14.
I only noticed my occasional pop on idle once I had the exhaust fitted.
Ed,
If it's not happening all the time there's a pretty good chance it's the coil packs. When you get the coils out, have a good look at the clearish plastic window on the side and see if there's any burn marks, bubbles in the plastic, cracks etc, etc. Also, pull the rubber boot off the end and check out the carbon contact ( and spring ) to see if it's shot. The carbon bit contacts the end of the spark plug and can errode over a long period of time.
When I had my HR31, sometimes the car would be OK but when the coils packs got hot, the fault would show up. I replaced my set with a set that were in much better condition and problem solved.
If you do need coil packs, give me a yell. I've got a bunch of really good condition ones.
Otherwise, have a good look at spark plugs, wiring, connection plugs etc for general condition.
Hope that helps you some :dry:
Had a couple of ignitor failures as mentioned earlier, this will give you simptoms you are experiencing, but as SKid said , start with the basics first, keep in mind the components you are talking about are around 16 years old.
Ed,
Hey dude if you figure out the problem make sure you post back here ok. Im running pretty much the same set up and have the same problem. Had my fuel pump replaced and after that it ran alot better but now its gone crap again so i need to start with some other ideas (which unfortunately there are alot of, my mechanic is convinced that my timing belts off by a gear or 2, but im 90% sure hes had to many spanners drop on his head)
Edited by r32 gts-turbo
I had pretty much the same problem in 1 X R32GTST, 2 X R33GTS's, 1 X R34GTT and 1 X Stagea and fitting NGK copper plugs and gapping them as per the above fixed it in ALL of them.
Why look for the complicated answer before trying the simple and cheap ($20) solution first.
:D cheers :P
and while you have the coilpacks out to change the plugs you could tape them up. kill 2 birds with 1 stone.
But then you won't know what the real problem was.
One thing at a time
Leave the plug cover off until you are happy
Then it is simple to check the coil packs if it's not the plugs
:huh: cheers :angry:
Edited by Sydneykid
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
