Now i know this may seem like a weird question,
Generally speaking. Would a twin exhaust of say 2.5" or one 3.0" flow more? And which would eb quiter.
I know there are considerations of bends/mufflers. But with most things being equal.
I mean the area of a 2.5" circle is 19.63 and a 3.0 is 28.26
I knwo there will be lots and lots of people who decide to laught etc. at this post. But i hope you get my drift.
Well any input would be helpful.
Thanks
https://www.sau.com.au/forums/topic/124723-exhausts/
a twin 2.5 has greater area than 3" and a is a touch bigger than 3.5", but this isn't to say that it will flow more. you'd really need to talk to someone who knows what they are talking about, but i think that the air in the twin system would be travelling slower than the 3.5".
noise wise the twin pipes is going to be much quieter as it would be having twice the mufflers.
https://www.sau.com.au/forums/topic/124723-exhausts/#findComment-2302769
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG is has not responded to my emails so far after purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
