Thermostatic Cooler Kits, Single/dual Filter Relocation Kits
not sure if this has been asked yet, but does the single filter relocation kit have the 2 plug holes for oil psi and oil temp sensors? if yes, sign me up plz.
  • Replies 125
Posted Images
167+ or 157 retail,
trade is still more then 125 each
by my reckoning if retail is $167 trade should be around $100. previous earls accounts were 40% off retail. maybe give them a call they may sort you out for volume purchase. either way it definately should be less than $125 and I would say they keep stock.
Guys stock is still very low on most parts - these kits have been quite popular, so if ordering please be advised there will be a wait :dry:
100, plus 4 fittings still
its ok i have sorted some out from the states shouldnt be long till they are here :)
Hi,
For just the filter kit, it shouldnt be very long - i can check tommorrow and let you know, im pretty sure they're in stock, its the thermostats that are low/out of stock at the moment :ninja:
im after the termo and core but am wanting stainless braided lines. will the just jap relocator kit with braided line fit the termo and core???
As long as the connections are the same, yes, i dont have the justjap fitting sizes so i cant tell you for sure though
(sorry for the late reply)
How long are the hoses?
Is it a DIY to connect all the fittings on this hose?
Still no pics of an installation of this kit so have to ask...On the mounting brakets that come with it: Does the cooler end up with the pipes connected to the cooler sideways or on top when fitted in front of the radiator?
Edited by Edge
You can mount the cooler up or on its site, its best mounted upright so both hoses from to the top of the cooler
the kit comes ready to install,
u just cut the hose to the size you need them install it,
there is 4 thermostats left
this buy is becoming a very big problem, none of the local suppliers have any of the perma cool gear in stock till the end of the year and all my gear is sold out and my order from the states wont be here till late this year
so please find out if stock is in stock or when its coming before placing a order
nothign has gone to plan with this group buy ;)
  • 4 weeks later...
just wondering if the kit can be fitted without the thermostat for now until the thermostats become instock?
cheers
Jeremy
I want a cooler, single filter relocation kit and a thermostat.
Let me know when stock is available so I can pay for the gear.
No worries :laugh:
cheers
Jeremy
It can but it means a bit more hassle in the future :D
No worries :)
It can but it means a bit more hassle in the future :)
k no worries.
i have to wait till the end of november to get my tomei pump so i cant put my motor in till i get that now. any ETA on this cooler gear?
cheers
Jeremy
Steve, hook me up with a single filter kit, k&n filter and cooler for the GTR33 please mate. Not worried about the thermostat. Need to keep temps under control when the new turbs arrive.......:)
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
