  • Replies 58
Got an email through at work saying Ultimate WILL be pumping on the 21st of July. From memory i think it said they should have it at all 18sites within the 24 hours????
SO when do we expect to see it down south Rosie???
https://www.sau.com.au/forums/topic/124898-ultimate-98/#findComment-2305717
In NSW, ultimate is generally 10c dearer than regular.
It's worth it IMO though! I can definitely feel the difference in power, and knock is much lower too - Lower than the 7-8% octane increase usually! more like 20-25% less knock compared to 91 ron!
https://www.sau.com.au/forums/topic/124898-ultimate-98/#findComment-2308397
Ahh sorry gotcha.. sorry for the mis-understanding.
Yeah thats one thing the world has got to understand - Oil companies are a bunch of greedy theiving bastards! If it doesnt make them lots of $$$ to release 98ron in Tassie, then they wont. They sure as shit aint doing it to make skyline drivers happy! :D
https://www.sau.com.au/forums/topic/124898-ultimate-98/#findComment-2308616
my bad :laugh: , i couldhave made my post a lil clearer lol :D, yeah, theyre just like any large corparation, e.g banks etc, its all about the $$$$ fark the consumer.
Edited by toffy
https://www.sau.com.au/forums/topic/124898-ultimate-98/#findComment-2308624
Found out today the media release and grand opening will occur in a Hobart servo. Brooker or Brighton?????? As for the price nothing has been decided yet
how about %1.00 per litre fark the goverment tax on it as they will get heaps in speeding fines ones we get it :wub:
but realy i hope its only aroung 10cents more than premo to keep it the same as the mainland.
https://www.sau.com.au/forums/topic/124898-ultimate-98/#findComment-2310772
