Well my car just dynoed 212kw @ 18psi.
My mods include:
Microtech LT-8
Custom Frontmount
3.5 inch dump to cat 3 inch for the rest
Hyflow T3/4
h/d Clutch
Vl pusher pump as well as standard intank
Standard air box
Well i don't know what everyone else thinks but this seams a little low for the modifications. I though atleast 257kw because have beaten a certain silva with a rb20 before.
The dyno was not in shootout mode and had a ramp rate of 100
https://www.sau.com.au/forums/topic/12491-just-dynoed-my-car/
Did you dyno it with the bonnet down?
Thats the best way to get a more realistic figure. It is always a lower figure too.
I wouldn't worry about the figure if it was an improvement.
The real measurement is beating that 'certain silvia' and doing some quick times around your favorite circuit or drag strip.
Stop getting all hyped about the dyno figure.
It's a peice of paper, just like toilet paper its only fit to wipe your ass on if its not being used to help tune a car.
So what if the silvias got a better dyno readout. Scan yours into the computer and change it with photoshop to read 1000rwkw, then you can beat him at the races AND in a dyno paper stand off!
Yes you can say i'm a little focused on the dyno readout, I guess 212kw is not enough. The tune on the car was pretty S&*t, as soon as i gave it a boot full it detonated the loudest i have ever heard it. Sooo in 2 weeks it will be going back on the dyno, the same one as the rb silvia.
I'll let everyone know how it goes!
:D
Hi sik32, is this an RB20DET? No adjustable cam pulleys? No injector upgrade? No adjustable fuel pressure regulator? No internal mods? Standard camshafts? No pod?
If it's a roller dyno (not hub) 212 rwkw is 360 bhp, that's pretty good for an RB20DET with the mods you have listed. I'm surprised it didn't run out of injector capacity.
I sort of agree with the other guys, except I reckon the dyno might be a bit optimistic.
PS; let us know the dyno shop that the Silvia runs on, I want to take my car there and get a good bit of paper to wipe my butt on as well.
My mods include:
Microtech LT-8
hey sik32,
I'm too am running a LT-8 on my recently purchased GTS-4.
Just wondering how you find the driveability of it in your RB20?
How's the economy if your just cruising along in 5th gear?
I don't think they have closed-loop cruise mode. So they don't use the oxy sensor, do they?
What about initial start-up?
I know the LT-8 doesn't use the idle stepper valve. (the thing on the end of the plenum) So do you have some sort of air by-pass valve to compensate for the greater amount of fuel at start-up?
I'm just asking cos I find that mine never starts cleanly especially after I haven't driven it for a day or so. Sometimes it even seems like it wants to stall itself cos of the lack of air (revs drop below 500)
As far as the economy on my car, it pretty bad considering that I hardly ever boost it around town. and I spend alot of time cruising in 5th gear. something like 350km to a tank:(
I haven't had a chance to dyno it yet but hopefully will in a few weeks.
anything you can enlighten me on?:P
ok Interloper, First of all I find Microtech a great computer if you are on a budget. Drivability is fine, as it drives like the standard computer, but there is a few things that dislike about my Microtech. Cold starts, the car sometimes stalls on the first turn of the key and will not idle properly until the car has warmed up properly. This seems to be a problem that most cars with microtech have.
Fuel ecomomy, well that went out the window along with my standard computer. Microtech is Very bad on fuel, this also may be caused by the tuning as I like it too be a little fat. Even when i'm off boost and on the highway it still sucks fuel like no tomorrow.
Yes approx 350km. If i could do it all over again i would chose apexi or motec because of money i have wasted on fuel i could have afforded either of these. No Joke
Good luck with it all:D
Ps thanks for the toilet jokes guys!!!!!!!:bahaha:
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
