Hey guys i need some help here
ive got cracks in my exhaust manifold (its a TRUST manifold)
does anyone know any good Zorst places that can look after me or where i can get a new manifold (Brand new one from trust is almost 4,000 dollars)????
and has anyone had similiar problems with a Stainless STeel Exhaust Manifold?????
https://www.sau.com.au/forums/topic/12528-help-cracking/
I woudnt go taking it to the average exhaust shop. Take it to a business that specialises in Tig welding and can do X-ray quality welds. Any company that does pressure piping. vessels etc or boilers etc. These people are qualified welders and will be able to fusion weld your manifold, or if they need to use a filler wire they will know the correct grade filler wire, though the Japs do use grades of stainless not easily purchase in OZ. At a rate of about $50-75 / hour you should be able to get it fixed for less then $150
Most exhaust shops would fall over themselves if asked to do a purged weld that would pass a tensile test etc. Welds should be stronger then the parent metal due to the localised heat treatment around the HAZ (heat affected zone)
As for stainless manifolds being prone to cracking, well i dont totally agree with this. It may be the design , but more likely the fabrication that causes the problem.
Grab a metallurgy text, mild steel relies on large corrosion factors to get the job done, hence the wall thickness and need for multiple passes when welding.
Many grades of stainless steel offer better temp properties, lighter weight, higher tensile strengths. Remember even steam bends are by nature used in water and gas systems, with much higher pressure then an exhaust manifold, but not very high temps. Saturated steam at say 450kPa is only about 135 degrees.
Some locally made stainless exhaust manifolds made from 304 stainless (about the cheapest grade and not all that suitable for high temps over 300degrees) can have probs, but if braced should still do the job if fabricated correclty.
Stainless 321 would do the job better and is available in plate and tube so lends itslef to manifold construction, albeit at a higher cost.
https://www.sau.com.au/forums/topic/12528-help-cracking/#findComment-230237
    • (it is a brand new ported mellings pump) I suspect the lack of pressure is due to the leak. It was *not* that low in other logs of oil pressure in the past. It wasn't that hot either, but not far off.
    • Would a Mellings oil pump be a viable option  From my time with a LS, and talking to tuners and LS specialists, the "weak" OEM oil pump is one of the first things they recommend to swap out if I was going to give the engine any high RPM I opted for a Mellings high volume, with the high pressure springs and I never had a issue with it Cost wise they are not expensive in the scheme of things
    • Just bought a 2002 Stagea 250tRS VR-X Four AERO VQ25DET and spent the last two weekends cleaning and detailing it.. still have to do the wheels and the engine bay but the rest of it came up nice. Imported 2011 to S.A. and I'm the third owner since it was imported. I met the guy who brought it over, he went to Japan and picked out the car, bought it and ordered the wheels. He also gave me a list of stuff he did to the car with receipts. Coil overs (I have the original springs), 3" exhaust from the dump pipe back no cat, Custom dump pipe,(I have the original exhaust), Plenum spacer, 18" custom Work XSA wheels (need restoring, I've made a start..), Shift kit put through the 5 speed tiptronic auto, TV and menus/screens changed to english, Australian DTV tuner installed in rear. I've just had four new discs and new pads as well as all the fluids including the brake fluid replaced. I have all the receipts for the last 15 years and the import papers in a nice folder. Car looks great, goes like hell but fuel economy is not a thing lol.. pics next..
    • I ended up in this rut again lol, and used a shit ton of filler. One thing I can't understand is, even after using a big long block and going in long X pattern strokes, I always end up at bare metal again with no filler, and my repair started at one end of the door and now I've chased my tail to almost the other end of the door. I was thinking of hitting the panel with a hammer where it might be a high spot and making everything low then filling it, I did this on a small section on my other door by mistake and I think I fixed it lol. Is this a bad idea? The other thing is with guidecoat, whether it's the powder or spray, after I sand all the guide coat off, it doesn't reveal anything for me in terms of high spots and low spots and makes it especially hard when it's bare metal (at least in powdered form), am I doing something wrong here, or likely a high spot I keep going over and creating valleys? Lastly, stupid question but, is it possible that after sanding if I only sand over the filler area where I know to be a dent that it's impossible for me to dig into that dent? Unless there are other problems which I missed.
