:D Correct me if im wrong but the pdf says weight 1201kg and over max allowable rim size is 2" above standard. (For cars post 1973)
Arent Skylines above 1201kg? :P
you might be right... i think it was either 1 or 2"... regardless, 19 is still a defect on a R32 and R33 as they come stock 16", but not R34
https://www.sau.com.au/forums/topic/125446-just-a-question/#findComment-2320473
check your tyre placard. it'll tell you the car's allowable rim sizes. on the r33's it says that 18's are ok with a certain width tyre. have a look at yours and it'll tell you. its usually on the inside of your door.
just a word of warning, when i had my 19s it cos me $290 EACH tyre for brand new ones. my mate owns a tyre place and he kept every 2nd hand 19" tyre he got in just for me which cost around $80 a pair. these prices are all mates rates too.
https://www.sau.com.au/forums/topic/125446-just-a-question/#findComment-2320523
I thought its 1" or 2" is allowable for rims above standard?
In width, yes its 1". But he's not asking if he can put 19" wide rims on the car.
As for diameter / circumference, this is what the VSI06 you linked to (which I assume you read before linking to it) has to say:
The outside diameter of the wheel and tyre combination must be no more than 15mm over the largest diameter wheel and tyre combination specified for the vehicle and not more than 15mm below the smallest diameter wheel and tyre combination specified for the vehicle.
Correct me if my interpretation is wrong, but when the RTA says that the diameter measured is the "wheel and tyre combination", they're not just looking at the increase in rim height to determine its legality.
As long as he can find a tyre with a low enough profile to fall within that 15mm leeway, he could run any rim size he wants (until the rim itself has the same rolling diameter as the OEM tyre's rolling diameter, of course).
So he could get 19x7.5 rims (with the correct offset, of course) and 215/35 R19 tyres, and they'd still be legal in NSW.
He could even go to a 20x7.5" rim with a 225/30 tyre and it would still be legal.
Edited by scathing
https://www.sau.com.au/forums/topic/125446-just-a-question/#findComment-2320546
    • Am I correct in assuming that the R35's are getting the classic skyline haircut off the odometer?  Quick search on carsales, there are 33 08 and 09 GTR's for sale, only 2 of them have more then 100,000km's on them (116,075 and 110,000 respectively).  And somehow there are about 25 for sale with around 60,000kms? Looks like the classic skyline haircut to me =/
    • @Stringycheese  Have you only gone to the one blue slip workshop?  There will be a heap of them where ever you live, good odds that the next place you go to will pass the car.  Unfortunately (or fortunately?) every blue slip / engineering workshop will be different and will be happy passing or failing different things - despite working from the same set of rules. It's kinda like 2 lawyers arguing over a piece of legislation, each saying their interpretation is correct. Might seem strange that this happens when it comes to getting a modified car passed, but this is very much a thing. A big part of the game is finding an engineer / workshop that is on the same page as you.
    • Bah. I daily mine. ~60km per work day, 10-12 thousand km per year. What's the point of having a dirty old Datto and leaving it in the shed. It needs to be driven and enjoyed while the govco allows us to do so. It will only be a few years before we're forbidden to even start up internal combustion engines.
    • Judging by that spring perch and the normal looking spring on it - not a coilover. Well.... it is a coilover, just a stock format coilover, rather than what everyone calls a coilover.
    • Yes it is. We get stock from Nismo directly. I'm happy to take photos/video of it as proof before I ship it with timestamps or whathaveyou.
