1993 Nissan Skyline R32 GTS-T
Gunmetal grey
188 RWKW (252 RWHP)
Modifications:
Engine:
• HKS 2530 turbo complete with Earls braided oil & water lines
• Blue-printed head
• SplitFire Super Direct Ignition System (coil packs)
• NGK Platinum spark plugs
• OS Giken adjustable cam gears
• Custom 650x350x80 FMIC with complete stainless steel piping kit & silicon connectors/bends
• HKS SSQV BOV
• K&N pod filter
• Greddy catch can
• Apexi N1 exhaust system with 3inch dump pipe
• New 3" high-flow cat
• Exedy 750hp single plate button clutch
• Professionally coated rocker covers
• Polished plug cover using gold anodised bolts
Fuel System:
• Bosch 650hp fuel pump
• Sard adjustable fuel regulator
• Upgraded fuel lines using Earls braids & fittings
Electronics:
• Blitz Dual-SBC boost controller
• Apexi SAFCII
• Re-chipped ECU by professional Japanese tuner
Suspension & Braking:
• Tien HA adjustable coil-over suspension
• Whiteline handling kit
• Cusco front strut brace
• Gold coated Nissan brake callipers
• DBA 4000 slotted competition brake rotors
• Bendix ultimate brake pads
Exterior:
• Lightweight 18 X 8.5 deep dish rims
• Genuine Nissan GTR front bar
• Genuine Nissan N1 FMIC inserts
• Genuine Nissan GTR aluminium bonnet
• Genuine Nismo clear indicators
Interior:
• Fully trimmed in GTR suede
• Momo race steering wheel
• Momo gear knob
• Apexi SACFII custom fitted into dash
• Apexi boost gauge fitted into existing A/C vent
• Blitz boost controller custom install (hidden inside ash-tray)
Sound system:
- Eclipse CD8061 head unit
- Eclipse SC8264 component speakers (woofers, tweeters & crossovers)
- Eclipse 32440 4-channel power amplifier
No expense has been spared in the preparation and maintenance of this R32. All the parts listed above were purchased BRAND NEW. It has been serviced every 5000km with quality products and only really driven on the weekends.
It has always been garaged and has now done 127,500kms of which 75000km were done here in Aus. The ECU re-chip and tuning has also been done in Aus to suit our temperature/humidity and 98 octane petrol. This car has only ever been run on 98 octane petrol in Aus.
The Genuine GTR parts mentioned above have all been professionally modified to fit the GTS-T. The Whiteline handling kit includes heavy duty sway-bars and complete bushing kit front & rear. The sound system in this car has to be heard to be believed. All the Eclipse components used are top of the range (the head unit RRP was $2000 alone!) and the sound quality is truly amazing.
This car put out approximately 190rwkw on a DynoDynamics dyno at Mercury Motorsport @ 1bar (14.7psi) of boost on 21/5/05. Since then the new coil packs have been added. With a minor re-tune this car would easily push 200rwkw on only 1bar of boost & with a standard ECU!!! Add an Apexi Power FC and bigger injectors and who knows what it could do...?
It is an unbelievable streetcar with big power, handling & braking to match. I am selling this beautiful car as I have purchased an investment property and require the money for a deposit.
Car is located on the northside of Brisbane, QLD. Please call/msg Robbie on 0407 175 417 anytime if you're seriously interested and have the money available. No time wasters please.
Price: $17,500 **SOLD** NO SWAPS/TRADES
Photos & dyno graph:
damn that car is hot!!!
and also very clean, looks great!!!!
maybe i am interested in, how about shipping 2 Germany? would u do or just sale 2 australia?
Ive got 15k waiting for a local car,Ive put a few offers in tonight no one seems to be interested in selling?
get back to me if the offers good ...cheers Simon :)
PM SENT
    • Well, yes, every CU on the bus is available via the Consult port, but whether the scanner you are using is capable of talking to the TCU, the ABS/TCS modules, etc etc, is what is at question here. Many of them are only for engine codes. So, if you have one of those, you won't know if the ABS is having a bitch.
    • That's now. R chassis Skylines come from a time when the tolerance in the ADRs was a bit more....slack. My car, on 235/35-17, which is damn near the exact same size as the original 205/55-16, is pretty much bang on correct indicated speed across the whole legal range. That's demonstrated with constant speed run over 5km, and GPS speed. It's just the luck of the draw. My particular speedo head has to be the thing that is "calibrated" that way, because everything else (the diff ratio, the gearbox and the speedo drive**) are all same same as most other Skylines. **OK, so the speedo drive is a Navara unit to drive the R32's cable, not the electronic unit than an R33/4 would normally have with teh same gear on it. Otherwise, I applaud your OCD tendencies, and I would do the same if I needed to.
    • Not too sure, I believe the Nissan consult port does everything? Also just filled up the reservoir to full and the light is still on. The float seems to move up and down fine.
    • The speedo's can be very conservative, when my Mazda NC MX5 speedo is showing 118kph, the GPS, and a calibrated radar.... cop mate.....hits me at around 110kph +/- 1 or 2 kph, and that is on a 215/45 17, stock tyres size is 205/45 17 as well, so weirdly conservative with stock tyre size When my Commodore speedo red 116kph GPS had me at 110kph on 255/40 17, so again conservative Google says manufacturers need to set the speedo from 4 to 10% slower than actual road speed.....for safety.....and compliance  After doing some offset and clearance measurements to see what can fit the NC on 17x8 +40, without guard rolling or rubbing anything at my current ride height, I've decided that when my tyres are toast, I'm going to fit 225/45 17 and see where that gets me IRT actual speed of my speedo and GPS/radar From the online calculator I should be still be doing around 5kph under an actual 110kph when the speedo is showing 110kph My ADHD requires that when I'm doing 110kph on the speedo, that the actual road speed is actually really close to that, and not alot slower And going from 205 to 225 still keeps the car within the %/mm allowable in the NSW vehicle rules and regulations, which is nice, as long as I'm looking at the latest version that is.....LOL https://www.nsw.gov.au/sites/default/files/2021-02/RMS-13.464-Light-vehicle-modifications-Vehicle-Standards-Information-No-6-November-2013.pdf
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
