Hi guys im new to this forum, im looking to buy a GTS4. i have found one that i really like and am gonna get it checked out by RACV soon. but i dont quite trust them as they arent skyline experts and probly just see if the car is gonna run for the next 6 months...
anyway...
its a 1996 or 1997 GTS4 M-Spec II (with the great looking fog lights at the front)
89000 kms on the clock
$14,900 is marked price but i will def negotiate
its very clean on the inside, there are to rips, tears or scratches that i was able to spot
i took it for a test drive and it seemed very smooth, no real rattles or clanks that i could hear
i was wondering if there was anything in specific that i should look for as i dont know very much about skylines.
any advice or suggestions would be greatly appreciated.
also if possible i would greatly appreciate if some1 would come with me to check it out in person.
Thank you in advance
-JACK
https://www.sau.com.au/forums/topic/125622-looking-to-buy-a-gts4/
thank you very much for that link, there is a lot of very good info in that list, so much so that i kinda feel overwhelmed with all of it. is there anyone in melbourne that would be intereseted in coming with me to check it out as i would rather have a fellow enthusiast looking over it that knows exactly what to look for instead of a mechanic that i dont know...
Obviously there is a lot more to look for then i expected and it would be at least a couple of hours worth of time, i am more then happy to pay for an honest and unbiased opinion from some1 that knows what they are looking at.
Any responce would be greatly appreciated.
Thank you
-Jack
yeh i took it for a drive and i really like the feel of the car, i have no problem with the car, i love it actually, i just want to make sure that the car is good quality and not just looks and what is RAA?
yeh i will definitely get racv check done but i dont want to go on the opinion of RACV alone as they are not specialists of any kind, they basically any old workshop mechanic that have an RACV sticker on their shop window, im not saying that they are bad but they may not be that good either, thats why i want some1 that has an in depth knowledge about skylines as there are obviosly heaps of skyline specific things to look for that probly wouldnt be on their general car checklist.
RACV Suck Arse... They were one of the main groups lobbying against imports that started all the new RAWS stuff. Not That RAWS is BAD but the whole thing was to try stop imports altogether. My mate is an inspector for RACV and they are told to give Imports a hard time...
Go VACC or a private mechanic is even better if you trust them. Where are you getting the car from, whoever it is if they want to really sell the car they will organise to take it where you want so long as it is not to far... If not, there is probably something wrong with the car
All R33 GTS4's are non-turbo, you know that right? Its only R32 GTS4 that are turbo.
And all turbo R33 GTS25t are Type-M. So i dont think the model you are referring to exists? Or am i wrong?
I realise that it is non-turbo, i dont want a turbo as im on P's and dont want the extra insurance cost. plus i like the 4wd capability of it :wub: Its an M-spec II as it has different foglight design to the standard M-Spec
When I sold my 180SX the buyer paid for an RACQ inspection. i had to roll my eyes at all the garbage on the report, including "engine surges under load". I said, yeah 15psi on a stock turbo will do that.
The guys father looked at me like I was an idiot and replied with "my turbo diesel ute doesn't..."
Far out. :thumbsdown: to RACQ inspectors (albeit it was 2001)
  • 1 month later...
    • Assuming the current ECU is stock, it might be worth getting hold of a nissan data scan cable. It could be as simple as voltage at the ECU
    • You need to test for spark when it matters - ie cranking. Kill the fuel supply, pull a plug and earth it, set up a camera and go crank. The spark needs to be consistent, every other turn of the engine. Not some sputtering of occasional spark. The reason I say this is because spinning the CAS in the air is not the same as spinning it installed, and if there is a bearing problem in it, the disk might work differently in the air than in the engine. You won't want to try to set the timing unless you know the spark is happening right.  Also, reconsider running the R35 coils against the stock ECU. They like a different amount of dwell cf the originals. It's not massive, you can actually run them, but it is better if you can adjust the dwell (which you can with Nistune in the stocker, or with an aftermarket ECU). Besides any of that - when you had the multimeter out, have you got power where it needs to be, earth where it needs to be (and when, in the case of igniter triggers), etc?
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
