  • Replies 238
Posted Images
Here is an update.
Oz R34GTR (Deposit Paid to Oz)
Ralph (Oz Work Friends) S15 Silvia (Deposit Paid to Oz)
Steve (Oz Work Friends) WRX (Deposit Paid to Oz)
Alan (Oz Work Friends) RX8 (Deposit Paid to Oz)
Matt (Oz Work Friends) WRX (Deposit Paid to Oz)
Darren (Oz Work Friends) WRX
Shane (Oz Work Friend) R32 GTS-T
Fatz S13 silvia
Fatz extra S13 silvia
Yogi R32 Gtst (Deposit Paidto SAU)
Boosted 300Z
Liz R33 Gtst (Deposit Paid to SAU)
88Silhouette R31 (Deposit Paid to SAU)
Bonks R34 GTT (Deposit Paid SAU Day)
J@Y R33 GTST
GTRedline R32 GTR (Deposit Paid to SAU)
Maybe
Steve GTS4
Someonestole
Primordial
Symo85
Ports
If some of the Maybe's come through then we will have 20 drivers, this may be one of the best turn outs ever!
Attention All,
Aaron has just gone to book the track on the 7th Aug and it looks like a group of 6 Oz cars have already grabbed the day, BUT! Aaron has spoken to the Oz cars group and they are happy to share the day with us. Aaron suggested we would split the groups and not mix the strret cars and the Oz cars. The cost will remain basically the same maybe drop to $180, as OP have ripped off the Oz cars by charging the standard rate. Aaron will keep his numbers only to our SAU group as we have enough numbers to almost support our own day.
We have another option, Tuesday the 1st of AUGUST is available and we dont have to share with the OZ cars.
Please let me know is you are available and keen for the Tuesday the 1st as I think this is the best option.
If you want to pull out for any reason your deposit will be refunded.
Im 100% Keen on the Tuesday. Please let me know ASAP if you can make it, so we can secure the drive day.
Thanks, and sorry about the last minute changes.
OK here is the update
Oz R34GTR (Deposit Paid to Oz) Ok with the 1st
Ralph (Oz Work Friends) S15 Silvia (Deposit Paid to Oz) Ok with the 1st
Steve (Oz Work Friends) WRX (Deposit Paid to Oz) Ok with the 1st
Alan (Oz Work Friends) RX8 (Deposit Paid to Oz) Ok with the 1st
Matt (Oz Work Friends) WRX (Deposit Paid to Oz) ?????
Darren (Oz Work Friends) WRX ?????
Shane (Oz Work Friend) R32 GTS-T Ok with the 1st
Fatz S13 silvia Ok with the 1st
Fatz extra S13 silvia ?????
Yogi R32 Gtst (Deposit Paidto SAU) ?????
Boosted 300Z Ok with the 1st
Liz R33 Gtst (Deposit Paid to SAU) Ok with the 1st
88Silhouette R31 (Deposit Paid to SAU) No Go :angry:
Bonks R34 GTT (Deposit Paid SAU Day) ????
J@Y R33 GTST ?????
GTRedline R32 GTR (Deposit Paid to SAU) Ok with the 1st
Maybe
Steve GTS4
Someonestole
Primordial
Symo85
Ports
Tuesday - Yeah I think I feel sick then......
BUT as it's a group SAU thing I'll go with the majority.
Would be more track time and the chance of the 'mock' races on the Tuesday.
It appears that whoever is managing the EC bookings have a bit to learn..............
if its the 1st then I'll be depositing my hard earned $$$
do I need fire extinguisher for this?
No extinguisher needed and once Aaron books the the 1st, which looks to be on hte cards, you can send in your deposit.
All,
It looks like we have critical mass for the 1st, but I still need to hear back from a few people. I have asked Aaron to secure the 1st ASAP and once this is done I will let you all know. If th 1st falls through then we can join the Oz cars. Thanks to everyone who got back to me quickly.
An update
Fatz extra S13 silvia Ok with the 1st
Bonks R34 GTT (Deposit Paid SAU Day) Ok with the 1st
J@Y R33 GTST ?????
Lingeringsoul R33 GTS Ok with the 1st
Maybe
Steve GTS4
Someonestole
Primordial
Symo85
Ports
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
