Hey.
Just a quick question about installing the catch can on my RB20det.
I have a aftermarket turbo and top mount manifold and the usual line which people plumb into is no longer.
Heres a quick picture of what i propose to do.
Is it correct? Is it the right breather to go off. Reason i went this one is it has had nothing on it at all since the new intake and everything had been on.
What do yous think?
https://www.sau.com.au/forums/topic/125887-rb20-catch-can/
Your intake plenum looks like a low cost option for those of us that want front mounts without the mass of intercooler plumbing.. what sort of money would a setup like that cost?? Isn't the fuel feeder/return for the injector rail mounted on the end of it? how did you get around that?
kris.
https://www.sau.com.au/forums/topic/125887-rb20-catch-can/#findComment-2324336
You can run it like you have in your diagram no worries, This is how mine has been run for 3 years and it works well.
Just need to make sure the catch can is sealed, as if it has a vented filter, you will get a massive vacum leak at idle.
Also you will need some sort of filtration in the catch can, steel wool in a stocking works well, otherwise it will not work
Alternatively you could just block of the PCV valve and run two hoses of the cam covers to a vented catch can, but I found this to be a bit smelly for everyday driving
Chris
https://www.sau.com.au/forums/topic/125887-rb20-catch-can/#findComment-2325132
Yer ive heard about putting steel wool into the catch can. it might be a bit hard with mine as the only real opening would be the drain hole down the bottom. Ill see how much i can shove into it though.
Cheers
https://www.sau.com.au/forums/topic/125887-rb20-catch-can/#findComment-2325803
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 馃槈. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 馃槏.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 馃檹 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 馃槈. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 馃槏 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
    • I've managed to find this: Nissan_Stagea_AutechVersion260RS (1).pdf
    • I believe @Duncan has given it a crack at Mt Buller before (in actual race conditions)
