  • Replies 45
Thats it i am going to wait here for you.
I sent you email this morning sweetie.
Over in BB house there is alot of contraversy about racism and why Damien and Turkan got voted because they werent white etc.
There a few a idiots making very dumb racist remarks but the general people are very good and saying that the reason why Damo got voted out was because he was a lazy sleazy self loving pig.
https://www.sau.com.au/forums/topic/126-shell-overe-here/#findComment-3001
Hahahahaha he just ate too much according to Mr muscles!!!! who cares what race he is, I hardly even noticed, like I said in my email i think he was quite goodlooking, but yeh he was a bit of a man-s**t hehe
I think he was trying to do a "christina and peter" and hoped it would keep him in the show longer.
Anyway, sorry Minh, but I'm gonna have to go off to bed now. I gotta go to work at 4pm....need some beauty sleep :wink: Oh and I got your email, will reply later tonight :wink:
https://www.sau.com.au/forums/topic/126-shell-overe-here/#findComment-3002
yeah he was a toss.. i got out of my car before he got out.. walked over to him.. and stood over him !!!.. then he said he was gonna fine me... and i started swearing and abusing him calling em money hungry motherfuc*kers..etc.. so he gave me a defect notice were there wasnt a fine.. so i said ok... have a nice day and goodbye..
i was so pissed .. i couldnt beliueve he just stood there and said nothing when i was yelling at him>?? eh.. oh well
https://www.sau.com.au/forums/topic/126-shell-overe-here/#findComment-3010
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
