I've posted a few threads on my r33 over the past two years, and the issue is still not sorted. Symptoms at present are a shocking idle that jumps all over the place, tries to stall, etc. Secondly, according to my boost guage the manifold vaccum is down. It sits at about 12, when it should be closer to 20.
Now, I have had this car looked at by multiple workshops, spent enough money to buy a new turbo, and swap tested just about everything bar the engine!! I'm deadset on the brink of getting a halfcut & swapping out the engine. It simply doesnt have enough fuel down low, and i dont know why... i have an untuned power fc, but i want the car to run well on the stock ecu before i get the thing in there. However, i use it for testing. If i dial in as much fuel as i can at idle then the car will idle nicely... and i mean as much as i can, as in the car should stall! With stock ecu the idle never stabalises... you can smell how lean it is, and if i hook it up to nissan datascan you can see the zero reading from the o2 sensor. Soon as i lift the accelerator off idle it starts to cycle. I have read every single thread on unstable idles, lean idles, etc, etc , and nothing has helped.
I've listed as much of the stuff i've dont as i can remember, so any advice on different things i could try would be appreciated. It's only been recently that ive noticed the low vaccum pressure... i think it's telling a big story.
What I've done
Cleaned ACC valve, swap tested AFM, TPS, O2, & Coolant sensors, swap tested ecu, ecu diagnostics, new battery, checked ignition timing, scoured for vaccum leak, changed plugs, gapped plugs, sealed up coils incase of cracking, changed fuel filter, checked fuel pressure, checked timing belt markings, replaced timing belt coz it was a touch loose, had injectors cleaned, checked compression (150psi across all 6)... thats all i can think of at the moment, but im sure theres more.
Cheers,
mick
https://www.sau.com.au/forums/topic/126027-r33-lean-at-idle/
do powerfc factory reset (youll loose all tune data)
ETC, DATA INIT
choose yes
power car off
turn car to ACC
turn off boost kit, ETC, FUNCTION SELECT
power car on
let it idle for 10 mintes (dont touch a thing)
turn on demister
let it idle for 10 minutes
turn on aircon
make sure idle is stable
turn car off
turn car on
see if idle is stable
if its not, post up what you have under SENSOR SW CHECK
ETC, DATA INIT
choose yes
power car off
turn car to ACC
power car on
turn on demister
turn on aircon
turn car off
turn car on
Have done this when i first got it... also checked everything sensor wise, nothing is out of whack, cept for what the o2 sensor sees, but ive tried 4 o2 sensors so i know it's only telling what it sees and isnt faulty.
honestly mate, from the way you've described that (running lean, idling badly etc) it sounds like you have an air leak somewhere...
you've checked all your intercooler clamps etc?
checked that a vacuum line hasn't been left off by mistake or something?
I hear that, and believe me, i have looked.... been over every clamp, every hose, sprayed around everywhere with soapy water & carby cleaner... if there is one, i cant find the prick!
Its possible after checking something, it was ok... and later on it wasnt.
So you possibly had one problem, fixed that and another arose from something already checked.
Just a possibility.
Is the car stock?
Where are you located and what specialist skyline workshops have you visted?
Just a possibility.
Is the car stock?
You may actually be right. It seems that over time the issue has *evolved*. It has changed symptoms, but the car has never been right. Not much done to the car... exhaust, front mount, intake, thats about it. Unfortunately no pro skyline shop in north qld mate.
To those who suggest vac leak, that is the front runner in my books too. I will thoroughly check this weekend & post back my findings. I suspect somewhere around the intake manifold.
cheers.
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
