I've posted a few threads on my r33 over the past two years, and the issue is still not sorted. Symptoms at present are a shocking idle that jumps all over the place, tries to stall, etc. Secondly, according to my boost guage the manifold vaccum is down. It sits at about 12, when it should be closer to 20.
Now, I have had this car looked at by multiple workshops, spent enough money to buy a new turbo, and swap tested just about everything bar the engine!! I'm deadset on the brink of getting a halfcut & swapping out the engine. It simply doesnt have enough fuel down low, and i dont know why... i have an untuned power fc, but i want the car to run well on the stock ecu before i get the thing in there. However, i use it for testing. If i dial in as much fuel as i can at idle then the car will idle nicely... and i mean as much as i can, as in the car should stall! With stock ecu the idle never stabalises... you can smell how lean it is, and if i hook it up to nissan datascan you can see the zero reading from the o2 sensor. Soon as i lift the accelerator off idle it starts to cycle. I have read every single thread on unstable idles, lean idles, etc, etc , and nothing has helped.
I've listed as much of the stuff i've dont as i can remember, so any advice on different things i could try would be appreciated. It's only been recently that ive noticed the low vaccum pressure... i think it's telling a big story.
What I've done
Cleaned ACC valve, swap tested AFM, TPS, O2, & Coolant sensors, swap tested ecu, ecu diagnostics, new battery, checked ignition timing, scoured for vaccum leak, changed plugs, gapped plugs, sealed up coils incase of cracking, changed fuel filter, checked fuel pressure, checked timing belt markings, replaced timing belt coz it was a touch loose, had injectors cleaned, checked compression (150psi across all 6)... thats all i can think of at the moment, but im sure theres more.
Cheers,
mick
https://www.sau.com.au/forums/topic/126027-r33-lean-at-idle/
do powerfc factory reset (youll loose all tune data)
ETC, DATA INIT
choose yes
power car off
turn car to ACC
turn off boost kit, ETC, FUNCTION SELECT
power car on
let it idle for 10 mintes (dont touch a thing)
turn on demister
let it idle for 10 minutes
turn on aircon
make sure idle is stable
turn car off
turn car on
see if idle is stable
if its not, post up what you have under SENSOR SW CHECK
ETC, DATA INIT
choose yes
power car off
turn car to ACC
power car on
turn on demister
turn on aircon
turn car off
turn car on
Have done this when i first got it... also checked everything sensor wise, nothing is out of whack, cept for what the o2 sensor sees, but ive tried 4 o2 sensors so i know it's only telling what it sees and isnt faulty.
honestly mate, from the way you've described that (running lean, idling badly etc) it sounds like you have an air leak somewhere...
you've checked all your intercooler clamps etc?
checked that a vacuum line hasn't been left off by mistake or something?
I hear that, and believe me, i have looked.... been over every clamp, every hose, sprayed around everywhere with soapy water & carby cleaner... if there is one, i cant find the prick!
Its possible after checking something, it was ok... and later on it wasnt.
So you possibly had one problem, fixed that and another arose from something already checked.
Just a possibility.
Is the car stock?
Where are you located and what specialist skyline workshops have you visted?
Just a possibility.
Is the car stock?
You may actually be right. It seems that over time the issue has *evolved*. It has changed symptoms, but the car has never been right. Not much done to the car... exhaust, front mount, intake, thats about it. Unfortunately no pro skyline shop in north qld mate.
To those who suggest vac leak, that is the front runner in my books too. I will thoroughly check this weekend & post back my findings. I suspect somewhere around the intake manifold.
cheers.
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
