Anyone got any idea what might have cause these failures? The gudeon pins have snapped in two. The same thing happened in two different engines. Both CA18DETs (similar to RB but 4 pot rather than 6), both using Wiseco pistons, both failed in only 100kms.
Its a strange one as I know of lots of people using Wisecos in CAs with no problems and yet this one guy has two identical failures. Any idea what he is doing wrong?
https://www.sau.com.au/forums/topic/126195-strange-pistongudgeon-pin-failure/
piston is not fauling on crankshaft counterweight is it, or crankshaft have excessive endfloat? unless pin is grabbing little end and piston, lubrication problem. never seen anything like it, thats big.
Those are the only pics I have Im afraid. Its a guy in another country thats having probs, I havent been involved with the build myself. The pistons are nothing out of the ordinary, as I say, they have been used with great sucess in a large number of engines to date so I cant see why they would suddenly foul on the crank. I can see maybe one set of pistons being mispacked by Wiseco but two, and both sets going to the same guy? Nah, too much of a coincidence.
Maybe the piston to bore clearance isnt correct and the pistons nipped up when the engines got hot but to snap the gudgeon pics? Ive seen the effects of hydraulic locking and even then it was the rods that bent, not the gudgeon pins snapping.
Very wierd.
Edited by bren
I've seen it before in a V10 Viper and it was a detonation issue. It broke 2 gudegeons and had 4 more cracked ones.
That was a brand new engine with Wiseco's. It was rebuilt and retuned (the right way!) and it's never had anothe problem since, even with the same pistons.
I tend to think that the gudgeon pin tried to sieze in the small end bush . You can see how the bush has tried to screw itself out of the rod and no doubt up against the inside of the pistons gudgeon pin boss . Since both pins are sheared in the middle it seems logical that half the pin was trying to stop the piston articulating with the rod and was the weakest link . Luckily the other half must have kept the small end located in the piston otherwise the rods and pistons would now be schrapnell on the road . I would be measuring up the broken and surviving pins to see if the tolerances were adequate .
I would also check to see if the propper lubrication was available to all four rods/pins/pistons .
Cheers .
Edited by discopotato03
ok. the only thing that causes a gudion pin failer is either a clerance issue or fauly materials. (dodgy gudion pin)
the fact that it shered could be due to the fact that its been hammering away at its self. elongating the piston pin bore and/or hammering the bush in the conrod.
to a point where it has hammerd it so hard that its fractured the gudion pin.
or.. partaly siezing in the pin boss or little end. ie.. one side getting galled andthe othere side being ok.
so basicly the cause is to little or two much clearance inbetween the piston and the gudion pin or two much clearance between the gudion pin and smallend bushing :D
ie.. poor engine assembly.
ps... if anyone for a minute thinks that detonation has caused this please slap yoursefl ;)
I'm with you on this one, detonation isn't going to do this. I would still like to see the big ends as they will probably show more of the story. If the little end is hammer the big end certainly is going to be showing signs of abuse as well.
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
