Hi All,
I am trying to make a comprehensive list of import cars and the years in which the different models were produced. So if you could please peruse over the information I have collected and advise me of any mistakes/inaccuracies that would be great. The purpose of making this list is so that I can classify performance parts under one of the corresponding descriptions.
The format is:
Common name (Chassis Code) Year Start/Month Start - Year End/Month End
180SX (PS13/KRS13) 89/4 - 91/1
180SX (RPS13/KRPS13) 91/1 - 93/12
180SX (RPS13/KRPS13) 94/1 - 96/7
180SX (RPS13/KRPS13) 96/8 - 99/1
180SX (All Series) 89/4 - 99/1
Silvia (PS13/KPS13) 91/1 - 93/10
200SX (S14/CS14) 93/10 - 99/1
200SX (S15) 99/1 - 02/8
R32 GTS (HR32) 89/5 - 94/11
R32 GTS-t (HCR32/HNR32) 89/5 - 93/8
R32 GTR (BNR32) 89/8 - 95/1
R33 GTS (HR33) 93/8 - 97/11
R33 GTS-25t (ECR33) 93/8 - 98/5
R33 GTR (BCNR33) 95/1 - 99/1
R34 GTS (ENR34) 98/5 - ?/?
R34 GTT (ER34) 98/5 - 01/6
R34 GTR (BNR34) 99/1 - 02/8
300ZX (Z31) 84/1 - 89/12
300ZX (Z32) 89/7 - 00/8
350Z (Z33) 02/08 - ?/?
Gti-R (RNN14) 92/1 - 95/12
https://www.sau.com.au/forums/topic/126323-nissan-import-production-years/
I'm just going on what I found from catalogues and the internet, if you could provide a month and year that would be awesome. I will look into all responses though.
thanks again
The r32 gts/gtst was only built up to and including 1993, the only r32 built in 1994 was the gtr... at least thats what i thought, probably wrong. Also i've never heard of a 1995 r32 gtr, is there such a thing?? surely any would be worth a bit if nissan stopped production in January 1995 (assuming the above information is correct)
Edited by r32line
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
