hi guys,
what is your opinion on running the intercooler piping back under the cooler and up the same side as the air box. i have been told that in order to run it up the battery (driver) side i will have to install a smaller battery facing longways. As it is an auto dont want to run out of charge and have to get jump started. as i have already purchased cooler with pipe goung out either side do you think the bend back under the pipe will be too restricting?
https://www.sau.com.au/forums/topic/126336-fmic-piping/
hi guys,
This is the style of pipework I use, goes though the inner guard under the battery in the Stagea (under the windscreen washer bottle in the picture which is an R33GTST, they have the batttery in the boot).
:P cheers :P
Edited by Sydneykid
https://www.sau.com.au/forums/topic/126336-fmic-piping/#findComment-2332581
I have piping that comes out under my battery, but I have a smaller battery, BUT I dont really need a smaller battery, for pics go through the pics in the link in my sig, I cfb right now :P
FYI My Oddessy battery has 880CCA, and it is teeeny tiny!
https://www.sau.com.au/forums/topic/126336-fmic-piping/#findComment-2332586
SKA- i was looking at your pics of your fmic piping under the battery tray, and i was wondering if your piping sits lower than your chassis?
But i think what stagon is talking about is running the piping through the battery tray ie:cutting a hole in the battery tray meaning he would have to turn the battery so it sits side on so the piping fits through with the battery still there.
like with most fmic kits you buy for 180's and skylines etc...
https://www.sau.com.au/forums/topic/126336-fmic-piping/#findComment-2332828
just a question when running the intake side under the battery tray through the side i now have no room for my window washer bottle :banana: hows everyone else doing it with the same setups??? or do u just get a smaller washer bottle from soemthing else????
mines the 26 but it still runs through the same spot just under the battery tray but just above the chassis rail.
ideas peoplz???
heres a pic of where my pipe runs through the body
Edited by CruiseLiner
https://www.sau.com.au/forums/topic/126336-fmic-piping/#findComment-2333085
Yes Cyrus, you are wrong. Your pipes go under your chassis rails like mine did. You have no hole cut.
As far as how low it sits, ive never had any problems at all with hitting my pipes. Infact, they sit pretty high compared to the front bar.
My pipes are for sale if anyone is interested.
https://www.sau.com.au/forums/topic/126336-fmic-piping/#findComment-2333592
cost me $250 and a case of beer all up, once i sold my standard intercooler :whistling:
only thing im yet to do is mount the "Modified" washer bottle
hey andy is that a modified stock stagea washer bottle is it or another one from a different car?
i gotta sort something out for mine now that i can actually drive the old girl ;)
my piping (3") and greddy type r bov (big sucker) are under the spot so i got absolutely stuff all room unfortunately. might have to make up an aluminium one to suit the room i have.
https://www.sau.com.au/forums/topic/126336-fmic-piping/#findComment-2335313
i gotta sort something out for mine now that i can actually drive the old girl :whistling:
i just cut off a section of the washer bottle, and used some plastic from a bucket to cover where it was chopped off. then used silicone to stop any leaks. not the most professional job but it sits inside the drivers side inner gaurd so you cant see it anyway.
i still havnt figured out how i will mount it yet, i'll work something out when i get around to putting it back on
https://www.sau.com.au/forums/topic/126336-fmic-piping/#findComment-2335375
I'd be a fan of getting a front feed manifold, or midifying the standard to front feed, for less clutter.
Ive heard that the shorter the inlet tract, the better the throttle response... thats what its about in the end, right? perfomance? id make it a short as possible. im not one for dressy engine bays, function over from under the bonnet.
MAKE it fit!
https://www.sau.com.au/forums/topic/126336-fmic-piping/#findComment-2335377
So has anyone actually cut the battery tray so the intercooler pipe can go through there.
Not the side like cruiseliner but the top section the actual battery tray?
So, where would the battery go? I know i dont want a battery in the same cabin as me incase I roll over and get battery acid all over me.
This isnt a Silvia :whistling:
https://www.sau.com.au/forums/topic/126336-fmic-piping/#findComment-2335473
i think you may be right there, jason. Cos it is designed to be side fed, really. But a GTR inlet manifold... would it fit, and would it be a better option? I can get greddy front feeds from a supplier in japan. worth it? or not unless you really go big?
https://www.sau.com.au/forums/topic/126336-fmic-piping/#findComment-2335511
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
