Its me again. I think Ive blown a headgasket on my Silvertop RB20DE. I was wonder, When I did my water pump, it was identical to the RB30E water pump. My question is, is the RB30 head gasket the same as the RB20 head gasket?
There is a $130 dfference, and I'm quite poor. Is it hard to get the head off? Should I watch for anything?
Thanks
https://www.sau.com.au/forums/topic/126485-rb20de-head/
well actually i believe u can shodan (but...im probably wrong again :blush: )
its just that u rarely do cause they are a smaller combustion chamber and buggery small ports :(
about the gasket itself - im not sure - but i do no that a rb26 gasket is the same as a rb30 - but probably not as reliable :(
https://www.sau.com.au/forums/topic/126485-rb20de-head/#findComment-2339017
from the r33 rb30 thread, I am sure that you still have to weld up oil galleries and so on. I'll go and have a check. It can be done, but its alot of work - and since the bore is so much smaller (as you say), I find it doubtful the gasket would fit properley.
Get the real rb20 gasket. cheaper than having to buy it anyway when the rb30 gasket blows out, and you have to pull the head off.... again.... for the same problem.
Oh - and about SHODAN:
part the first
part the second
https://www.sau.com.au/forums/topic/126485-rb20de-head/#findComment-2339474
Thanks
You must use an rb20 gasket nothing else will fit.
Have you checked the price of an rb20 head gasket from Nissan
I priced a genuine gtr rb26 gasket and it was only $77
If the genuine rb20 gaskets are more than that I'll sell you one for $70.
Pm me if you are interested.
https://www.sau.com.au/forums/topic/126485-rb20de-head/#findComment-2339914
I'll keep that in mind, and I'll give them a cal l tomorrow. I'll let you know. Thanks!
https://www.sau.com.au/forums/topic/126485-rb20de-head/#findComment-2341706
Ok, I rang Nissan. and they wanted 116.25 >.<
Ive got 14 bolts on either side of the head, there are three left in the middle, and they appear to be a little larger then 10MM. Do these bolts need to come out in order to get the head off? Or are they just for something else inside the head.
Its really stiff to get the head off, so I'm not sure if I need them out. Any help would be great as soon as possible as I'm trying to get the head off today!
https://www.sau.com.au/forums/topic/126485-rb20de-head/#findComment-2348228
There will be two or three smaller (8mm from memory) bolts outside the head that also need to be undone. One is at the front near the water inlet, the others are at the back. This is based on an RB25 and RB30 so RB20 my be slightly different.
https://www.sau.com.au/forums/topic/126485-rb20de-head/#findComment-2348486
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
