Ah okay, here's my numbers if someone could add them in. They start at 60km/hr and go through to 183km/hr. Also I really like the idea of PHP/SQL page, would be awesome to be able to compare so many different cars/modifications at the click of a button.
55 63 73 85 87 90 95 98 103 106 110 114 120 127 129 138 147 151 163 167 173 180 190 197 198 199 201 201 202 202 202 203 204 204 204 203 197 195 193 192 190 181
  • Replies 101
Is it possible to make it so that you can enter either road speed or rpm? I have a dyno sheet that is neatly broken up into 500rpm major and 100rpm minor increments which makes it easy but most people have ones that have road speed.
Here's a spreadsheet that will calculate speed based on rpm or rpm based on speed. You will need to know your tyre size, gear used, ratio for that gear and final drive. You can change the series of rpms or speeds to suit.
The example is using a R34 GTR in 5th gear for the rpm series used in the power spreadsheet.
It would be interesting to see how accurate the speed calculation is as it is theoretical and doesn't take into account real world conditions.
speed_rpm_calc.zip
It'd be good if the whole idea was comparing apples with apples.
I know its hard to do, but to compare the performance of a GT30R with a HKS 2835proS [as examples] would be a good thing. But to do this you need [ideally] two cars exactly the same or one car using both systems. This will never normally happen.
I know at the moment there are only a few results posted, but what happens when you get 20-50 results, the graph would be flooded.
To overcome this situation, maybe the whole exercise needs to be split up into stages of performance development.
More complex, but better definition.
I'm definitely interested too, I think it's a great idea that will end up getting a lot of use, especially as the number of cars added into it grow. It will also save a lot of people from posting threads asking about what sort of power they can expect from specific mods/turbos etc.
Will also allow people to have four or five of their own graphs to compare against each other.
you would be able to pick up to say 10 graphs and they display.
Could sort via highest, best average between 4500 and 7500 etc. etc.
Stop talking and get on with it..............lol. Sounds very good to me, it will be interesting to see what makes power and where they make it.
BTW I'll bring my dyno chart in tomorrow and provide some some figures.
I haven't mentioned my daily rate yet ;)
Ok, this is a spare time project so don't expect results yesterday. And while I will listen to suggestions don't expect miracles.
The first phase will consist of:
- a database to store car, rpm (any rpms should work and not specifically those in the spreadsheet), power at each rpm(kw), engine type, turbo type, and a description field to outline mods.
- a php page with a list of cars
- a graph page showing output for the selected cars
- possibly a page to add your own data (if this gets abused I will pull the site)
Once this is done I will start looking at extras/wishlists.
And if someone else is going to build the same thing speak now and I won't bother, as I can't be assed with duplicate effort.
Now we have the rules, I'll start building. :)
Rules sound good.
We need also to have the graph work on kph as well as RPM and should be either.
The problem with just RPM is that a lot of charts are in kph. Also different wheel sizes and stuff will effect rpm but not speed.
A lot of dyno operators are now printing out logs of the dyno run every 2kph. See attached.
Thanks heaps for taking this on man. its really tops!
Wow that was quick. I did start a page before with car, engine, mods, comments etc that people could enter their data into. Then they could search/view the list of cars in the database and select the tickboxes for the cars they would like to see on the graph... That was the idea. I have only done the page which drops the info into the database. Sounds like you got this under control Willo, but shoot me a PM if you want help anywhere.
This would be very easy to implement a login using SAu forum name and password to keep it locked down to memebers only, however that will need access to the DB to check the encrypted password against...
    • (it is a brand new ported mellings pump) I suspect the lack of pressure is due to the leak. It was *not* that low in other logs of oil pressure in the past. It wasn't that hot either, but not far off.
    • Would a Mellings oil pump be a viable option  From my time with a LS, and talking to tuners and LS specialists, the "weak" OEM oil pump is one of the first things they recommend to swap out if I was going to give the engine any high RPM I opted for a Mellings high volume, with the high pressure springs and I never had a issue with it Cost wise they are not expensive in the scheme of things
    • Just bought a 2002 Stagea 250tRS VR-X Four AERO VQ25DET and spent the last two weekends cleaning and detailing it.. still have to do the wheels and the engine bay but the rest of it came up nice. Imported 2011 to S.A. and I'm the third owner since it was imported. I met the guy who brought it over, he went to Japan and picked out the car, bought it and ordered the wheels. He also gave me a list of stuff he did to the car with receipts. Coil overs (I have the original springs), 3" exhaust from the dump pipe back no cat, Custom dump pipe,(I have the original exhaust), Plenum spacer, 18" custom Work XSA wheels (need restoring, I've made a start..), Shift kit put through the 5 speed tiptronic auto, TV and menus/screens changed to english, Australian DTV tuner installed in rear. I've just had four new discs and new pads as well as all the fluids including the brake fluid replaced. I have all the receipts for the last 15 years and the import papers in a nice folder. Car looks great, goes like hell but fuel economy is not a thing lol.. pics next..
    • I ended up in this rut again lol, and used a shit ton of filler. One thing I can't understand is, even after using a big long block and going in long X pattern strokes, I always end up at bare metal again with no filler, and my repair started at one end of the door and now I've chased my tail to almost the other end of the door. I was thinking of hitting the panel with a hammer where it might be a high spot and making everything low then filling it, I did this on a small section on my other door by mistake and I think I fixed it lol. Is this a bad idea? The other thing is with guidecoat, whether it's the powder or spray, after I sand all the guide coat off, it doesn't reveal anything for me in terms of high spots and low spots and makes it especially hard when it's bare metal (at least in powdered form), am I doing something wrong here, or likely a high spot I keep going over and creating valleys? Lastly, stupid question but, is it possible that after sanding if I only sand over the filler area where I know to be a dent that it's impossible for me to dig into that dent? Unless there are other problems which I missed.
