Hi all,
I have a major problem (i think) with the car. Since the last service (2 fridays ago), the car has been running fine. But then today when I was coming back from a very long drive (180klms), I noticed that the temp needle was going up and then down a bit. I thought this was just normal, so I didnt bother with anything. But then later tonite, after I came back from my bros house (about 5 mins away), the needle went right up.
My dad and I opened the hood, and there was a horrible smell. We knew that it was due to leaking coolant or lack of coolant. The water pump looks to be intact, but below the engine, there was a lot of liquid. That means the coolant is leaking froms somewhere there. We have checked the pipes as well, everything seems to be ok. I dont know where else to look.
Do you guys know what I can look out for as the main culprits for the leakage? We have filled up the coolant reservoir and the radiator, with a mix of coolant and water. But its still leaking. I am thinking of taking it to GTAutos for them to have a look at it, but I would appreciate any advise/pointers that you guys can give me.
Thanks in advance.
https://www.sau.com.au/forums/topic/126680-leaking-coolant/
coolant can come from
rear: turbo feed pipe that is behind the head, and is fed from the rear of the plenum. heater hoses
side: oil cooler, heater feed hoses, feed from thermo housing to the plenum. turbo water feed @ turbo
front: radiator hoses.
Edited by Craved
https://www.sau.com.au/forums/topic/126680-leaking-coolant/#findComment-2338802
This could mean that your water pump needs replacing. Happened to my mates R33 and was told that there is a small hole that will leak water/coolant when your water pump has had it, nissan mae it this way as a warning sign. You can see it if you look hard from memory. He was also told that once it starts leaking it should be changed fairly soon as it won't last much longer.
If it is your water pump then arrange to get your timing belt changed at the same time if it's close to needing it.
Good luck with your vehicle man
https://www.sau.com.au/forums/topic/126680-leaking-coolant/#findComment-2338821
Thanks for the info bud - but I changed the water pump 5 months ago (the timing belt and all were also changed). I do see something that looks like a crack, but hte pump is completely dry on the outside - nevertheless, I will get Wayne and Jarrod to have a look at it again.
https://www.sau.com.au/forums/topic/126680-leaking-coolant/#findComment-2338830
passenger side in the middle ???
sounds like turbo's water feed :blush: bit fiddly to get to though
can be feed or return, banjo bolts at return at block, and the turbo for feed and return .. feed comes from a rubber hose from behind the head
https://www.sau.com.au/forums/topic/126680-leaking-coolant/#findComment-2338882
First, if it is coming from the "middle" of your motor but cannot trace it back to a point source like a coolant hose, then it is likely your head gasket. Second, change your oil to make sure it does not look like chocolate milk. If it looks like chocolate milk, you have problems. It is either a cracked head or blown head gasket.
https://www.sau.com.au/forums/topic/126680-leaking-coolant/#findComment-2339071
Thanks for the heads up guys.
Craved: Its on the drivers side (towards the middle) - so im guessing its got nothing to do with the turbo.
Darius: i have checked the oil - it seems to be ok. I had the car serviced just 2 fridays ago by RE Customs.
i might check with them to see if they noticed anything abnormal about the car when they did the service.
https://www.sau.com.au/forums/topic/126680-leaking-coolant/#findComment-2339106
Update: Ok, we have found the culprit. Its one of the Cylinder wall plugs. Seems that the bastard has rusted, due to the improper coolant mix being used. Uh!!!!! Thank god its not a major problem like a blown gasket, but I believe that the repair work will take a long time!
https://www.sau.com.au/forums/topic/126680-leaking-coolant/#findComment-2339112
Yep - by monday she will be back to running like a beast :blink:
(and probably need a good clean too)
I emailed wayne in the morning - and he said that things like this happen if the car has not been looked after well. Eitherway, he is gonna help me change it so im wrapped!
https://www.sau.com.au/forums/topic/126680-leaking-coolant/#findComment-2341368
lucky you cahnged the water pump previoulsy otherwise the same thing woulda happened to the fins on the inside of it.. rendering it useless.
are you getting them all replaced now? dont want it to rust through another one
https://www.sau.com.au/forums/topic/126680-leaking-coolant/#findComment-2341468
Well, I have to get him to check it on monday. I could only see one that was rusted beyond recognition. Hopefully get the whole thing replaced. The waterpump is fine from what i can see.
Just hope it doesnt take a long time, cos i cant live with out the car :blink:
https://www.sau.com.au/forums/topic/126680-leaking-coolant/#findComment-2341537
Just wondering, how long would it take to replace these welsh plugs? Do they have to extract the whole engine? I know the have to flush out the coolant before they do anything, but if they have to remove the whole engine - then im gonna be charged shit loads.
https://www.sau.com.au/forums/topic/126680-leaking-coolant/#findComment-2347913
  • 4 months later...
just bumping my own old thread
Took it for a service today to RE Customs - got a call back from Ray, prognosis negative - yep damn welsh plugs are haunting my ass again!
Warranty wont take care of it. and it looks like im going to have to pay shit load to get that fixed....
damn damn welsh plugs :wave:
https://www.sau.com.au/forums/topic/126680-leaking-coolant/#findComment-2733281
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
