hi guys
i purchased a rb25det 45v3 turbo from my mate and i was installing it today when pulling the elbow off it i noticed oil inside so i cleaned it up, and there is a bit of oil near the turbo fins
should i be worried about something here? i wiped it all down and just put the turbo on my car a few hours ago
but im yet to start it and i have to finish doing the rest of the lines
there was quite a bit of oil in the elbow leading to the inside.. anyone seen anything like this?
https://www.sau.com.au/forums/topic/126968-rb25det-stock-turbo/
the other reason for oil in there is if the front oil seal is on its way out. they will normally leak a very small amount due to the type of seal that they use.
nah, came from a popped motor; says to unwise me that the turbo is fine and that the oil was simply the result of 'blowby'. however Im no mechanic.... LOL
start her up and see if she squeels like a stuck pig, if she doesnt all is hopefully good !
(love the chips n lemon comment, lmao)
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
