Thinking about pumping out all four guards on the 34 to accomodate some wider wheels and get a beefier look... been quoted around $1k including spraying from a prestige panel beaters in the local area... was just wondering if anyone here has any reccomendations or advice?
So if you have photos, experience with this type of body work, do's/don'ts please kindly post them up.
Looking at getting this done in a month or so ;)
Thanks
Stan
  • Replies 45
Hey maybe you're right and the rears are the same :( Mmm, does anyone have any contacts?
BTW Steve, cheers for that contact yesterday... called them up and sorted out those fittings - they'll be delivered to me today (not expensive either)
thats a bad example of the Z Tune dude they got different guards then GTRs... rears have the attechment lips and fronts are slightly wider and have that stupid looking edgy top part.
I had a pair of genuine front GTR guards but sold them for $600.
For fronts you could save some dough and get fibreglass ones as opposed to GTR ones.
Would make the car lighter too.
However I know they're made for 32 & 33 but not sure for 34.
There's always GTR front guards on Yahoo Japan. Some need a bit of filler and a respray but that's par for the course and you were going to respray them anyway. These are the best option for the front.
The rears are doable with factory rear quarter panels as well but you're basically going to have to respray the whole car that way. There's been a bloke trying to sell a GTR rear quarter panel on Yahoo for a couple of weeks now he's only asking 40,000...
The GTR rears are significantly different to the GT-T rear guards...
I've been looking into this too, Stan, and cannot seem to break the 1G quote for getting front and rears pumped. That does seem like the best solution, though.
Someone was actually selling a set of fibreglass GT-R guards on ebay modified to fit a GTT last week. Sold for like $600 or so I think.
$1k was a ballpark figure I was given last night when I made an enquiry with the shop. Given that they do European cars mostly (repairs to BMW M3 guards) they would be more expensive but have the right tools and experience.
I'm going to have a hunt around, will post up if I find anywhere that's a little lower but of the same quality.
Why dont you buy the guards, and spray them and fit them at NBP?
You guys have the spray gun dont you? I think i remember seeing something like that when i was there
That way the cost should be HEAPS lower
LOL Steve, spray painting is the one things we WON'T do even if we have the gear.
I'll shop around; can anyone confirm if the GTR guards will just bolt on or will they need modifying?
    • I’m here solo don’t have any hands to help so haven’t hit it with a timing light
    • When you crank your car, and hit it with a timing light, can you see a steady crank timing?
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
