I've painted a set of wheels myself in the past and they turned out nice but they looked pretty average after about 3 months. You just can't get the same results with a pressure pack can as you can getting a proper job done IMHO. Just got my R32 GT-R wheels done properly by a spray painter and they look like a better job than what I did straight away. Cost was $260 for 4 wheels.
Who did it for you?
Magman?
Who did it for you?
Magman?
Nah, just a spray painter in the Shire near where I live. Trades as "Tynan Smart Repairs" in Kirrawee.
I would say that Magman would be one of the best options but too far away for me.
MY instructions for painting rims....
Go to supercheap, buy 2 cans of black gloss @ $2.99ea
put rims out back of house in sun, wash wheels, cover with black paint, thin coats.
Continue doing this 3-4times
dont bother taping over tyres, they are black anyways
final check before putting them on car, touch up bits you forgot.
Put on car, touch up again
tyre black..
touch up every now and again.... for $2.99 i couldnt care less if i have to touch them up :cheers:
Ed
ive seen harlequin style paint cans at supercheap, gotta be something similar...
nightshades your rims bro!
Chris if you need a hand man let us know, we do it ultra dodgey style and spray the tyres too! no need for tyre black for a while ;)
hahaha good one Ed :)
thanks for the offer mate!
Its all good - i did them a couple week ago its just now the tyres them selves have gone all Emo on me!
so monday next week im going tyre shopping! :)
  • 4 weeks later...
and by the look of it - it needs to be lowered too :)
It also looks like you need a tripod or some kind of camera stabilisation, too ;)
My wheels are getting repainted at the moment. I'm getting them redone from titanium to a darker gunmetal (hopefully they'll be the same shade as R32 or R34 GT-R rims).
Will post some before and after pics when I get it all back.
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
