Hey all,
after buying a 3" dump pipe (basically just jap, but 2nd hand) my mechanics and i installed it yesterday.... i had a stock down pipe and a slightly larger front pipe, highflow cat, full exhaust from there back....
Anyways been driving it the last few days, and its alot more responsive off boost, exhaust a tad louder/different note(not alot) and it goes a bit harder in the higher rev range...
Anyways, when spooling up, it feels like an absolute nugget, it wont hit full boost(11psi) untill 4000rpmish, spools alot longer, and generally dosent have that low down punchyness that it used to have.....
The car used to hit full boost by 3000rpm and would absolutely rocket from low revs (although choke up high)....
Im rather annoyed (as you get when car isnt right) and im scanning my brain to figure wat the problem is, took it for a drive tonight, after resetting the computer, farken cold night and 100octane, the car SHOULD rocket but it feels like a warm summers night with shit petrol....
Now as for the problem, i cant see any exhaust leaks, the only thing i think it could be is possibly the O2 sensor, maybe got a knock, or dosent like being back in there (didnt clean it just chucked it back in) other than that maybe another computer issue or maybe im being totally wrong and this is how the car should feel/drive. but if it stays like this the stock downpipe is going back in....
So please all, give me some ideas, comments, problems, anything that will help me sort out this issue......
Thanks
Ed
https://www.sau.com.au/forums/topic/127312-dump-pipe-problemsissues/
Hey
o2 sensor is only used for cruise. You can disconnect it if you like, it won't affect it when you floor it.
full boost by 3000rpm. are you sure? My rb25 hits full boost at like 3000rpm. On my friend's r32, it used to hit 10 psi at about 4000+rpm.
Just fitting the dump definitely would not make it slower. If you compare it to the stock dump, it really opens up the exhaust.
Hey
hey man, no problems with the strut brace :P
it definately feels laggier for some reason, it used to hit fill boost alot sooner than it does now, either that or my guage is reading wrong, ill check that out tomorrow, just thought id get some ideas and opinions.....
The car feels a whole lot more responsive off boost its just this boosting issue that is annoying me... i hope its not just me being neurotic :)
Hey all,
Thanks
Ed
Sounds to me like you are getting a bit of R&R mapping. It is quite common for that to occur as the boost is building, because the airflow increases much faster than the ECU is mapped for. Hence it throws in a bit more fuel and retards the ignition. This goes away once the boost is stable and the ECU is seeing more normal rpm and airflow increases. You can see it all the time on the dyno graphs as a power dip, flattening off in the curve.
Do you have any tuning capability? SAFC, Power FC, rechip? That will enable you to fix it.
I am also confused by your use of the terms “dump pipe”, “down pipe” and “front pipe”. The standard configuration goes;
Dump pipe --> engine pipe --> cat --> cat back exhaust
Many of common front stages of the exhaust combine the dump pipe and the engine pipe into once piece. Save weight, a couple of flanges, nuts, bolts and a gasket.
:action-smiley-069: cheers :wub:
Edited by Sydneykid
Ive got the same dump pipe - is beautiful and nice and responsive.
But - the dump pipe connecting to the turbo, the welds - they are not that great. Pretty poor in fact, in my opinion. But for $200 you cant complain too much.
I bet youve got a leak there - take it off and reweld around the edges. Costs bugger all. Fixes up the welds around that area and can then be guaranteed it aint leaking from there!
Would agree with SK.. maybe it's getting a higer rate of flow.. R&R'ing.. which will of course feel slower to you..
See how you go easing it onto boost.. Also - I don't see how the boost could change e.g. yeah, ran a bit higher whilst the computer was learning, but sorted itself out in <1km..... as I don't believe that the boost would be controlled by the computer in any way..
Might be wrong.. maybe it's time for a Dr. Drift ECU tune!!
:) cheers :)
It definately feels like its retarding in some way, ive got an aftermarket chip in the car that was a copy of a specifically tuned RB20 chip (exhaust, cooler, more boost new maps), bought it off another forum member, its got new ignition, fuel maps, higher rev limit, no speed cut and a few other small tweeks, when i changed it from stock to the aftermarket chip there was a HUGE difference, car revved more freely, more power etc etc. Not a problem with it since ive had it.
What i meant was down pipe= straight from turbo to the "front pipe" and these 2 pipes were replaced with the "dump pipe"
Tangles- it was 2nd hand, no signs of leakage....
Links - Whilst the ecu is relearning its maps, getting all the settings etc it boosts higher (13psi) but goes like an absolute nugget once its relearnt it goes back to normal....
Damn if this is going to be a costly exercise, ill just stick the stock dump and aftermarket engine pipe back on, went alot harder than it does atm......
Ive reset the computer again, but havent run it in, so ill do that tonight when i get home..
At the moment you have a guesswork tune in there. You have now done enough mods so that guesswork is no longer good enough. First job, spend $50 (or so) and get yourself along to your local dyno. You want 4 graphs from the one power run, being power, torque, A/F ratio and boost.
Post them up and we can give an opinion. If it needs a retune, $200 or so should cover it.
:) cheers :)
Edited by Sydneykid
That downpipe sounds like the one I got that definately improved response etc AFTER I had it rewelded and ported extensivly because of the crap construction. The way they inserted the 3" reshaped pipe into the flange left a lot to be desired and I am sure would have impeded and disrupted flow.
Anyway LISTEN to the voice of reason!! (SK) :(
:wave: cheers :(
aiight, whos the best blokes in sydney for the job?
Slight update, took her for a drive the other night. it wont even spin 2nd in the wet, used to do it as soon as boost came on.
When the engine is cold, it drives like it used to (boosing early) but when she warms up she definately becomes slower,
Im going to try the stock computer chip and see if that adapts to the new dump pipe better, if not the stock engine pipe and larger front pipe is going back on untill funds let me get a cooler and a proper tune...
Ed
    • Nice, thanks for sharing your progress....that's a pretty long list you are putting into it!
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
